I made a SDR recording of the PMR 8 sunday net last sunday, hearing stations 30+ miles away one of which was on Holme Moss near the transmitting station.
PMR446 Holme moss recording
- Call Sign: G4RMT
Re: PMR446 Holme moss recording
Interesting how they're nearly on 446.2MHz exactly - so are people using the standard frequencies (that's 19375) or the more sensible ones without the offset from normal spacing?
This is a fault in the SDR that I was using at the time being slightly off frequency, I can confirm they were in fact on the correct spacing on 446.19375 (Channel 16).
If this was on CB Radio you would hear more snap,crackle and pop then a bowl of rice krispies.
- gmham
- Call Sign: 108TM154
Brillant lovely and clear audio. What antenna you using for rx on 446mhz ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
Sirio CX-440, a small antenna but performs exceptionally well on 446.
- gmham
Okay thanks heard about this particular antenna a few times now.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: 26TM7373
Ordered the CX-440 today, will be interesting to see how it compares to what i'm using now.
SDRPlay RSP1A + CrossCountryWireless Loop
Icom IC7410 + thunderpole boomerang
Retevis RT90 (opengd77) + Diamond x50
Yupiteru MVT-9000MKII, Baofeng DM-1801 (with opengd77)
- Werthers
