PSU recommendation for TS-590SG
cb4ever104
Re: PSU recommendation for TS-590SG
Post by cb4ever104 »
OK . I've been doing a bit more digging . You need to remove the leg (not led) off that IC . Think it might be pin 10 . In the video I saw the guy used a couple of SMD diodes . I'll need to look at it once I eventually get round to doing the job to see how much space there is . The video I saw was in German . There's probably other ones out there that I haven't seen yet .
Call Sign: Lemmy
Post by ch25 »
As described on attached image.
cb4ever104
Thanks Chris . I saw another guy in a video (different PSU model) just remove the pin , without adding the diodes . Anyway . I'll use the diodes . I won't be able to start the work until the end of the year , but I'll post back once I have .
S.
Call Sign: Lemmy
Post by ch25 »
If you lift pin and leave not connected, OVP will be disabled. That's bad.
cb4ever104
ch25 wrote: 24 Jun 2021, 07:58 If you lift pin and leave not connected, OVP will be disabled. That's bad.
OK . Thanks . I'm assuming then that the 3 diodes in series will increase the cut off threshold by +2.1V ?
Call Sign: Lemmy
Post by ch25 »
Correct.
cb4ever104
ch25 wrote: 24 Jun 2021, 09:17Correct.
:thumbup:
cb4ever104
ch25 wrote: 22 Jun 2021, 19:30 Without OVP mod, when you raise voltage up to 13.8V, under load OVP will trigger and switch off PS. 13.2 is the limit, where OVP don't trigger under load.
HP really didn't want people opening these things up , did they ? :lol:
Took me about 45 min just to get this far. Anyway. Now I need to get my x-ray specs on and mod the thing :thumbup:
cb4ever104
Diodes in. Now for the fun of reassembly :)
cb4ever104
Job done !
Thanks ch25 for your help with this.
Call Sign: Lemmy
Post by ch25 »
Good work!!
cb4ever104
ch25 wrote: 10 Feb 2022, 23:05Good work!!
:thumbup: :thumbup:
