CRT SS-7900 PROGRAMMING HELP NEEDED
- WARLOCK
- Call Sign: 26TM134
I am trying to programme a CRT-SS 7900 , I have got the programme cable /downloded the programme frm the internet BUT when i try to connect the radio to the computer all i get is CHECK CONNECTION / RETRY OR CANCEL someone said i need to get the drivers for the cable ??? how do i do this . also i have told to make sure that i am useing the correct com port how do i find this out , So in other words i am compleatly lost and am in need of HELP ???
- Buick Mackane
Re: CRT SS-7900 PROGRAMMING HELP NEEDED
Ask mr weety to change your name to MR HELP. Your driving me fooking nuts with your never ending help threads
I thought the idea of a forum was to help amongst other things.
- Buick Mackane
Yeah i totally agree, But this guy takes the p1ss, He starts threads and most of the time he doesn't reply to them, Or repeatedly asks the same questions which have already been answered, And i'm not the only member who has a problem with it,Alan Pilot wrote: ↑16 Dec 2020, 20:05 I thought the idea of a forum was to help amongst other things.
- MrWeetabix
- Admin
- Call Sign: 26TM175
The programming software can be found here - http://www.ewwa.net/software/SS_7900_Setup_1.00.exe
The Driver can be found here - https://www.ewwa.net/drivers/Prolific-v1.80.zip
The user guide for the driver is included in the ZIP file, but I've posted it below...
To be fair, if you're not brilliant with PCs, USB Programming and installing drivers on a PC, then you're probably better off spending a little more time manually programming the radio instead. Probably quicker than faffing about with drivers and that.
The CRT 7900 Manual is here - http://www.cbradio.nl/crt/Manual_CRT_SS7900_ENG.pdf
Specifically this...
Warlock, that Took me 5 mins on google to grab it all. I think some members get a little frustrated with you because you always seem to be asking questions about the latest whatsit you've bought or want to buy (which isnt bad thing). Perhaps a little research ahead of buying would serve you well?
Yes, forums are here to help, but as I have just shown, the information is out there to get relatively easily. There is a search function on the forum which is very effective and there's also Google, which is the default font of most knowledge. Hopefully the above will be of use, but if you really aren't great with Tech, maybe stick to old-school radios going forward.
Can I ask that even when frustrated, we all behave cordially towards each other and try not to let things escalate. Thank you.
- Buick Mackane
no probs craigMrWeetabix wrote: ↑16 Dec 2020, 22:42
Not noticed him asking all the time.
And yes i have replied to many posts on forums with "have you tried the search" or even with "google is your friend".
Does he ever say thanks' ??
- Buick Mackane
Not very often, Thats another sore point with members, Don't get me wrong iv'e nothing against the guy personally, I don't know him, But his HELP Threads are getting ridiculous
I clicked on "new posts" earlier today and his name was on 4 or 5 of the 8 posts there.
- Auldgeek
- Call Sign: GM0BRJ
Couldn't agree more. I've lost count of the times I've helped & you almost never hear a thing back. I simply don't any longer.Buick Mackane wrote: ↑17 Dec 2020, 08:50Not very often, Thats another sore point with members, Don't get me wrong iv'e nothing against the guy personally, I don't know him, But his HELP Threads are getting ridiculous
Auldgeek - Drew
- Mikel
It is a nightmare trying to explain how to investigate Windows com port and driver problems on a forum so maybe your best bet would be to sell that radio and buy one pre programmed, but if you want my advice, not from the dealer who shall not be named in Redruth, Cornwall.
- WARLOCK
Thanks for the advice Mikel but as for the dealer in Cornwall have bought many things from him in the past and have had no problems . I have bought another cable and software from Knights problem solved ?
- Mikel
Ah, great stuff, let us know how you get on with it.
- WARLOCK
As i said pronlem solved .
- Mikel
No you said 'problem solved?' with a question mark on the end which suggests you were asking a question. But if your problem is solved then I would say to you - great stuff
