SS9900 DC LOW?
del6600
New User
New User
Call Sign: 26CT2711
SS9900 DC LOW?
Post by del6600 » 12 Aug 2019, 08:12
Hi,
I have a SS9900 radio.
When I switch on and call out all I am getting is "DC LOW"
I have tested the 13.8v 20A psu, that's ok.
To confirm this I took the radio out to my car and plugged it in
with the same result. I re-flashed the radio with the original
software it came with 16 months ago. Same problem?
Anyone any ideas what the problem is?
Hopeful
del
26 TM 2711
26 CT 2711
del6600
New User
New User
Call Sign: 26CT2711
Re: SS9900 DC LOW?
Post by del6600 » 12 Aug 2019, 08:48
Hi,
Hopeful
del
I have just adjusted the voltage settings now 14v > 9v was 14v >12v
When I key the mic now all I get is a black screen, when I release the key I get a beep.
Beeps and roger beeps have been turned off.
I am beginning to wonder if the TIP36C PNP Power Transistor or the 4 13N10 finals have gone?
26 TM 2711
26 CT 2711
13EL121
Call Sign: 13DA121
Re: SS9900 DC LOW?
Post by 13EL121 » 14 Aug 2019, 05:24
Yes, check voltage regulator and finals at first. Sometimes they burn through due bad cooling design.
