JFK PA-338 board Roger Beep delay
13EL121
Call Sign: 13DA121
Post by 13EL121 » 13 Jan 2019, 15:27
Hi, any idea how to make the beep longer in a JFK with PA-338 board?
Thanks and 73,
Ralf
dt307
Call Sign: 163dt307
Re: JFK PA-338 board Roger Beep delay
Post by dt307 » 16 Jan 2019, 03:18
change value of c166
schematic http://78roger.free.fr/president/schema/jfk(pc-338).jpg
163dt307-chris
― Albert Einstein
13EL121
Call Sign: 13DA121
Post by 13EL121 » 20 Jan 2019, 11:04
:thumbup: Thank you Chris! Will give it a try.
13EL121
Call Sign: 13DA121
Post by 13EL121 » 20 Jan 2019, 12:14
Maybe it looks like C100 0.047? The schematic is not very clear.
13EL121
Call Sign: 13DA121
Post by 13EL121 » 20 Jan 2019, 12:39
Found it! C156 is the cap for Roger beep delay. Thanks for your help Chris! :thumbup:
dt307
Call Sign: 163dt307
Post by dt307 » 20 Jan 2019, 13:53
all good happy to help ..... most have a cap in series with the beep on and off switch
163dt307-chris
― Albert Einstein
13EL121
Call Sign: 13DA121
Post by 13EL121 » 20 Jan 2019, 16:12
Yes same as Superstar 360FM or 3900, but I was not able to find it in the schematic. You have seen what I have not seen... The beep switch in the schematic.
I doubled the value of the Tantal cap and the beep sounds like a Jackson now. :D
