Not picking any hf up on my Yaesu frg100.
N1ova
Post by N1ova » 13 Jan 2019, 10:08
Help please, picked up a Yaesu frg100 yesterday. At the moment i only have a discone. I can't pick any hf up just normal radio. Should the discone pick anything up?
dwabbit
Call Sign: m1cdq
Re: Not picking any hf up on my Yaesu frg100.
Post by dwabbit » 13 Jan 2019, 10:27
probably not. just get a long length of wire longer the better and connect it to the radio.
Tigersaw
Call Sign: GW6RRL
Post by Tigersaw » 13 Jan 2019, 11:52
Discone is not the right antenna. Assuming you have it connected to the 50 ohm SO239 and that is selected as the input, disconnect the plug so only the centre pin is connected, you may pick a few things up, but as suggested, you really need a long wire connected to the 500 ohm (HI Z) input
N1ova
Post by N1ova » 13 Jan 2019, 14:13
Made a longwire up from an old extension lead and still can't pick the shanwick volmet up.
Tigersaw
Call Sign: GW6RRL
Post by Tigersaw » 13 Jan 2019, 14:34
N1ova wrote:
13 Jan 2019, 14:13
Plugged into the HI Z connector, and the little switch pushed over to select it?
N1ova
Post by N1ova » 13 Jan 2019, 15:37
Tigersaw wrote:
13 Jan 2019, 14:34
N1ova wrote:
13 Jan 2019, 14:13
Yeah am flooded with intefirence its high up the signal meter.
