AOR have pulled a rabbit out of the hat !
Metradio
Call Sign: G7HID
Post by Metradio » 21 Dec 2018, 20:59
AOR have just released a firmware upgrade for the AR-DV1:
This is a BETA firmware of which only purpose is for you to test voice decoding of the traffic channels of Tetra trunking networks.
This new decode mode is named T-TC (for Tetra Traffic Channel)
IT WORKS.... I just set up a search on the UHF Airwave base frequencies from 390-395MHz, adjusted the squelch as described. It stops on active speech - although it is encrypted - it passes the audio and displays the time slot..
Mike
Metradio
Call Sign: G7HID
Re: AOR have pulled a rabbit out of the hat !
Post by Metradio » 22 Dec 2018, 17:20
DV1 searching between 390 and 395MHz, 12.5KHz steps, Airwave encrypted speech. The reverse video number (1-4) on the left is the active slot number.
Mike
tetra1.mp4
pete_uk
Post by pete_uk » 26 Dec 2018, 13:32
So near, yet so far, eh?
Metradio
Call Sign: G7HID
Post by Metradio » 26 Dec 2018, 18:12
Next time someone says that "you cannet listen to Police transmissions any more !", you reply that yes you can and they now speak in Klingon ...
The Airwave traffic is all encrypted but a lot of business use TETRA is in the clear..
Mike
stratocaster
Post by stratocaster » 08 Jan 2019, 19:10
It does work OK, but if on auto and running a scan through a set of frequencies it doesn't get any hits. I appreciate this is a beta version but hopefully a final version will work fully on auto settings.
