Display bulb cover for 2830
KlondikeMike
Call Sign: 9WR2000
Re: Display bulb cover for 2830
Post by KlondikeMike » 16 Dec 2018, 19:48
The Collector wrote:
16 Dec 2018, 09:30
Have you got a picture of the LED strip in place KM?
It might help others decide to do it that way if it's not too much hassle.
OK, here goes. Disclaimer: The images you are about to see may be disturbing to some viewers, Please be advised.
The display unit must be removed to work on freely. You will not be able to do this work safely with the display module in the unit. While you have the unit out, you may as well replace the 3 electrolytics that are on-board.
As a hot knife tool I used a length of 8 gauge copper wire in a 140w "Weller" type soldering gun. The fumes generated whilst the melting process is going on is excessive and work should be done in a well ventilated work-space.
I have multiple parts radio's so this is my first attempt on a donor part. I did not bring out the calipers or any digital measuring tools to mark the target. I just marked the edges and burned away plastic housing until the space was created. I cleaned up the edges as best I could but did not want to spend to much time "perfecting" my work and damaging the housing any further.
The display has been powered up on the test bench and looks good. I will be installing it into a working HR2510 that I previously had installed a single LED (and was disappointed with the results) shortly.
9WR2000
Post by The Collector » 16 Dec 2018, 23:09
Would "Dremmelling" it be an easier/neater option, or do you think the dust generated would be able to get into the display?
astradyne
Moderator
Moderator
Post by astradyne » 17 Dec 2018, 12:38
16 Dec 2018, 23:09
The white plastic cover is easily removable from the screen PCB. It's held in place with one screw and one positioning lug. Any work can then be done away from any sensitive components. Just remember to clean the cover well prior to refitting it. You don't want dust or debris showing up on the display and then having to dismantle the whole thing again.
I'd agree with using a small rotary cutting tool. Much safer and a considerably tidier appearance. Alternatively (and the method I'd prefer) would be to insert the LED strip from the front of the plastic housing while it's removed, then feed the supply wire out through the existing bulb holder hole. The LED strip will find its resting point inside the holder as it's fed toward the narrower rear of the unit. A touch of hot glue or superglue would be enough to hold it in place. No cutting, no melting, no mess and this latter method would enable you to return the display back to stock should the need arise.
Parts for the Lincoln's etc are pretty scarce these days so I'd never consider using the method KlondikeMike has detailed above.
KlondikeMike
Call Sign: 9WR2000
Post by KlondikeMike » 17 Dec 2018, 18:19
astradyne wrote:
17 Dec 2018, 12:38
I agree that a tidier appearance would be beneficial. When you burn things, it gets a little messy. This is where the Dremel tool can come into play. It can be used to clean up the edges. Using the tool to cut a narrow notch as I have would prove to be difficult. I would have concerns about cracking and bits flying off that I don't want to fly off. Maybe masking would alleviate, I do not know. As the saying goes "Like a hot knife through butter". You could use a Dremel tool on that butter but which is the better tool for the job?
The idea of inserting the strip from the front is plausible but does come with issues. A "resting" point comes with the strip being bent in a concave manner and the lighting not being distributed evenly. The power wires would be better fed off through a side cut hole. Securing the strip with some hot melt glue "may" work. Issues of the glue not securing to the housing or the strip would have to be experimented with. If one wanted to replace a strip mounted like this (to put in another color or replace defective), one would have to go through a complete disassembly to get to the strip. All of this to protect the sanctity of "the housing".
Whereas, a installation of the strip in the manner shown would allow for easier removal in the future. My method being crude but effective. This is my first attempt at getting this strip installed and there is always need for improvement. The strip slides into the notch and is secured in a flat manner by the edges of the housing. Light is dispersed evenly on the front panel. The strip can be easily removed in the future. Once the housing gets its edges cleaned up with the Dremel and installed back in the radio, one has to look hard to see what little is exposed under the front bezel and wires to see any of the housing. For the purists, this type of work is cringe-worthy and one could still install the original wheat lamp if desired. I am not concerned about keeping everything stock and original with "matching serial numbers" sort of thing. I look to improve upon by using modern technologies in vintage gear.
I posted my work expecting feedback and you gave me things to think about. I appreciate that. In this case, I will remove the rough edges and get a tidier appearance. I have another strip to install. I will use my hot-knife method and notch out the housing. With the covers back on and looking at the radio from an operators view, the LED strip looks great. When I'm done with this first strip installation, I'll post photos to confirm.
9WR2000
Post by The Collector » 17 Dec 2018, 22:04
That plastic piece looks like the sort of thing that could possibly be replicated by someone with a 3D printer and the associated know-how, so that it could have a groove designed in ready to accept an LED strip.
KlondikeMike
Call Sign: 9WR2000
Post by KlondikeMike » 17 Dec 2018, 23:49
17 Dec 2018, 22:04
Great idea! I'll look into it.
9WR2000
Post by The Collector » 18 Dec 2018, 17:23
Get them on sale with the LED strip included and you might make a few quid here and there ;)
steepeljack69
Call Sign: 26SF333
Post by steepeljack69 » 26 Dec 2018, 13:04
Once again many thanks to Alexthegasman for all your help and for the bulb covers,much appreciated. Also thanks to everyone else who's input has been use full.Would like to see the finished project with the led strip
KlondikeMike
Call Sign: 9WR2000
Post by KlondikeMike » 08 Jan 2019, 20:18
I cleaned up the housing with a Dremel wheel. Cleaned up well. I installed the strip and added a little hot melt glue. Looks good. I will install completed assy. into the radio this week and post final results.
9WR2000
