President Lincoln 1 Squelch problem
delta-xray
New User
New User
Post by delta-xray » 09 Nov 2018, 12:40
Hi guys,
my Lincoln 1 has a strange problem with squelch.
When radio is on and tune it on squelch, it stays in squelch even if you turn the knob back.
Only thing to put it "out of squelch" is to switch radio off and on again.
Adjusting VR102 does not solve this issue.
Anybody an idea? Leaking capacitors maybe?
Thanks! Ton
KlondikeMike
Call Sign: 9WR2000
Re: President Lincoln 1 Squelch problem
Post by KlondikeMike » 09 Nov 2018, 16:41
I am presently working on a Lincoln v1 right now. It has a few problems including a similar odd behavior with the squelch as well. First step, replace ALL electrolytics and then start troubleshooting. I'm half way through and when I get them all replaced I'll post my results.
9WR2000
1968neil
Post by 1968neil » 09 Nov 2018, 18:43
I have some notes from back in the day for the same fault, Can remember the fault was intermittent on mine so as Mike says maybe electrolytics drying up ? There are two to check in my list, either way id replace them anyway :
Neil
Q109
D115
C37
C33
TP = Pin 8 IC101
delta-xray
New User
New User
Post by delta-xray » 09 Nov 2018, 19:55
Thank you guys for a quick response.
I will start to recap the whole transceiver, parts are ordered today.
Will post the result as soon as i finished the job.
Best 73 from the Netherlands!
Ton
delta-xray
New User
New User
Post by delta-xray » 14 Nov 2018, 13:12
Replaced all caps on main board and Lincoln is perfectly
back in business!
1968neil
Post by 1968neil » 16 Nov 2018, 17:28
Thanks for the update :)
Enjoy ..... :)
Call Sign: n0call
Post by ch25 » 16 Nov 2018, 17:33
So... which cap was responsible for bad sq?
Users browsing this forum: No registered users and 8 guests
