Hiya folks, I've got myself an adapter to use PL259 connectors on my little blue dongle. The choice of antennas to try it with are a home made inverted v-dipole for 11M, or a mag mount with a modulator thingy on it.
The little dongle does get a little bit toasty warm after a while and im worried that by connecting a large antenna i might damage the thing.
The reason i think i might damage it is because for some reason ive got it in my head that a wire can picks up radio waves and if its long enough can generate some voltage or current and a down converter needs to be used?. I dont know if this is true or not, and i wouldnt imagine a cb antenna would damage my dongle,and i dont know what a down converter is or does either?
Just thought id get some opinions to see if its safe to hook up or not?
Mark
RTL2832U dongle antenna worries
- loudassassin
- radiogaga
- Call Sign: 26TM399
Re: RTL2832U dongle antenna worries
Yes, it’s safe to hook up. I have a variety of dongles and never had a problem with any of them being connected to any antenna. You over course need to be mindful of lightning and front end overload. It doesn’t quite work they Way you have described your worries. (Ish)
The received signal is not going to make the dongle warm (unless you overload the front end) I’ve got (had) around 10 SDR radios of various guises and they all get warm, not hot to the touch. The SDRplay duo seems to be the least effected.
https://www.rtl-sdr.com/rtl-sdr-heat-di ... al-camera/
I use my cheap blue dongle as second ADSB RX, it’s fine there with a filter, rubbish without and around half as effective as the FlightAware Pro. I have found the cheaper dongles a little deaf below 60mhz, compared to the SDRplay.
Don’t know where you are but there is little 11m activity here on commercial gear let alone hunting it on a dongle but good luck...
If it were me i’d go inverted V.
PS****Just one thing, don’t transmitted in close proximity to the RX of the dongle or antenna, that could fry it, and quickly too. (I may have misunderstood your question and that’s what you were asking)
PPS **** maybe worth using a small USB extension to get the dongle in some free space to keep it cool.
PPPS**** you could lower the sample rate to reduce the work th dongle is doing, that would keep it cooler but I really wouldn’t worry
Far more interesting uses for the SDR than 11m
30TM399 Northern Costa Blanca
- loudassassin
Thanks for your quick reply and putting me at ease, so now I'll liberate the laptop from the lad when he's at school and pop the inv V on it and have a flick around. Happy days!
The USB extensions a cracking idea, i'll have a route through my box of bits im sure there's one somewhere.
- radiogaga
You would be far better to try with a VHF and UHF antenna and give that a go. Loads of airband and Marine stuff to have a go at, or 446 up on UHF.... That’s just to start.
Here’s some fun uses
https://www.rtl-sdr.com/rtl-sdr-tutoria ... te-images/
https://www.rtl-sdr.com/tempestsdr-a-sd ... diated-rf/
https://www.welle.io
This really is scratching the surface
- loudassassin
Thanks for the links, the unintentional RF looks interesting. The weather satellite is something ive been wanting to have a go at, i used to try and get HF fax when i had my FRG7 comms receiver.
I'll perhaps have a go at making a vhf and a uhf antenna for receiving, i do enjoy a little project now and then and there's got to be loads of info on home brew antenna's on here to go at.
I've been using my dongle with its tiny supplied antenna with ads-scope for plotting planes on a map and also general flicking through, im looking forward to seeing what different antenna's will drag in.
- radiogaga
You'd be surprised how much a small mod to that supplied antenna can make to ADSB. If it looks like this, try cutting it down.
or better still keep that as it as a knock up a free standing spider for ADSB
For VHF and UHF, keep the antennas vertically polarised.
Here is a good link: https://m0ukd.com/calculators/slim-jim- ... alculator/
For 137 weather satellite, I use this http://lna4all.blogspot.com/2017/02/diy ... tenna.html
Keep that one horizontal.
- loudassassin
The scrounge for materials begins, i like to try and recycle stuff if possible. I've got a couple of old mobile antennas that can be butchered for parts for the spider one. The J-pole looks easy enough to make and as its only for receiving i shouldn't encounter any problems there.
Again thanks for the links and all your help
- radiogaga
No worries. I'm a bit obsessed with the SDR stuff.
