Best colour to spray Concorde2 cases
steepeljack69
Call Sign: 26SF333
Post by steepeljack69 » 13 Jul 2018, 08:02
Hi if anyone can help?i got a Concorde 2 a few days ago,my problem is the cases are in a bad state,front and bezel r fine.If anyone has sprayed cases b4 would be good to hear what u used.Obviously it’s black,but many varieties of black Also is it Matt?Thanks,spraying isn’t my thing so any help much appreciated.
Tim
Call Sign: 26AT239
Re: Best colour to spray Concorde2 cases
Post by Tim » 13 Jul 2018, 08:51
Is the original paint smooth or 'textured'. Let's start there.
SECA-11m
Post by SECA-11m » 13 Jul 2018, 09:41
One of the guys on the CT forum restored a Hy-gain 2795dx. He made a post about it, and went into lots of detail too. Pages 1, 2, 3 & 10 cover prep, filling, painting and getting the factory dappled effect. he made a great job of his.
http://charlietango.co.uk/topic/7885155/1/
http://charlietango.co.uk/topic/7885155/2/
http://charlietango.co.uk/topic/7885155/3/
http://charlietango.co.uk/topic/7885155/10/
I know Doctors, Dentists and Architects.
Wanted: President City Talker
steepeljack69
Call Sign: 26SF333
Post by steepeljack69 » 13 Jul 2018, 10:05
Yes have seen it,I am not after those results just to tidy cases up.He doesn’t tell u what paint he uses,only don’t use Halfords spray stuff!so what do u use,I know he does it satin black then black gloss but what brand?its a smooth finish,like I said iam not doing a restoration just tidying up the cases.
Post by Admiral » 13 Jul 2018, 10:33
Try Poundland black.
steepeljack69
Call Sign: 26SF333
Post by steepeljack69 » 13 Jul 2018, 12:22
Hasn’t it shut down?is it spray or in a tin to use with a brush?sorry never seen it in any of pound shops .
Post by Admiral » 13 Jul 2018, 12:31
They have spray paint in my local Poundland, any colour you like so long as it's black. In the bicycle accessories bit. Don't forget to ask the assistant how much they cost.
Buick Mackane
Post by Buick Mackane » 13 Jul 2018, 15:58
Admiral wrote:
13 Jul 2018, 12:31
You jest mucker, But i almost bought a dog toy in a poundshop But it turned out to be a tenner, Needless to say i put it back,
And dont forget primer too, Otherwise the paint will peel off
Some days will stay a thousand years, Some pass like the flash of a spark, Who knows where all our days go ~ Stuart Adamson.
Post by The Collector » 13 Jul 2018, 18:45
It's Poundworld that's in trouble, Poundland should be okay. The 99p shop's went a while back I believe.
Ours does grey primer, gloss black, gloss white, satin black and matt black at times. They're not too bad quality-wise but the pattern is a bit spattery...but what do you expect for a quid. On this particular occasion, that wouldn't be a bad thing.
Primer it, satin black it, flick gloss black off the end of a stubby brush on it for the real-deal effect if you wish then let it dry for a few hours. Then coat in satin clear lacquer for a bit of protection ;)
Black Spirit
Post by Black Spirit » 13 Jul 2018, 19:37
I always use Carplan satin black, Matt and gloss i personally think look horrible.
steepeljack69
Call Sign: 26SF333
Post by steepeljack69 » 13 Jul 2018, 21:14
It’s only to tidy the cases up,not botherd about textured finish,yes I will strip the paint,primer,black satin and then black gloss,does that sound ok?Everyone thanks for all help,I was just going to buy a black spray and that was it!now I know the correct way,why is Halfords spray no good?am just going off the guy who did the fantastic job on the hygain
SECA-11m
Post by SECA-11m » 14 Jul 2018, 00:00
I've also used Carplan & Hycote brand Satin with decent results, cheap & cheerful.
I found the poundland paints never really cure properly.
If possible try to use same brand primer & paint. Sometimes different brands can react badly with each other.
astradyne
Post by astradyne » 14 Jul 2018, 15:50
Don't forget to put a couple of layers of lacquer on too to protect the paint. It will be much more resilient to marking/scratching in the future.
steepeljack69
Call Sign: 26SF333
Post by steepeljack69 » 14 Jul 2018, 16:16
Cheers everyone I will give it a go next week and if it goes ok I will put sum photos up on forum,don’t be expecting anything good,it’s not my thing but if I make a total mess I will send them for doing professionally.
Post by The Collector » 14 Jul 2018, 19:30
A quick tip or two - let go of the nozzle at the end of each sideways stroke or you'll possibly build up too much paint at the ends and risk runs.
Start the spray a few inches from the item and let go a few inches past it.
The tendency will be to do most of the action with your wrist, but try and keep your wrist still and let your arm swing control the spraying (more important with metallics as a rule though). It's only cases though so you'll be fine.
Best to do lots of fine layers with a few minutes drying time inbetween, rather than one or two thick coats and risks runs.
Pop the casings onto say a small box so you don't have any edges stick.
Coat the edges all round first gently, then do the sides and the main surface last.
Try spraying from about 8-10 inches away with quick passes at first until you get the coverage right for each fine coat.
Don't spray outside if it's windy, or inside a draughty garage etc where dust could be whipped up onto the paint.
You can use a hot-air gun to speed-up the drying process inbetween coats (and avoid "blooming" in the cold), but in this weather you shouldn't need it. Don't let it fully cure though between coats though for days, as the next layer won't bond to it as easily and you could risk flaking in tbe future. You may have to lightly rub it all down with wet 1200 grit wet&dry paper to get a "key" otherwise.
A clean oven on about 40 degrees will bake it all on, especially after the final coat of satin lacquer.
Google and Youtube will aid you if you're not sure about anything. I'm not an expert on paint other than having sprayed about 35-40 radios in my time, so others may have different or better ways of doing it.
Give it a go. If you mess it up, you can always rub it off and start again ;)
Good luck.
