SDRangel
timberwolf
SDRangel
Post by timberwolf » 03 Jul 2018, 17:56
Can anyone help please? I was awestruck by how easy & quick it was to download SDR Angel. Works well on Airband am and copes perfectly with nfm two-way simplex. I just can't get it to monitor & demodulate local dmr. Even though my Uniden 230 blasts out daleks-with-machine-guns, when I key-in the frequency, I get nothing. I can see the broadcast on the waterfall but after honing in on the signal there's zero. I can't even get the time-slot, colour-code & talk group (does anyone know how to make SDR Angel do that ???). If anyone can advise me what to do, I'd be eternally grateful.
kilimax
Call Sign: GM0BRJ
Re: SDRangel
Post by kilimax » 03 Jul 2018, 20:59
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
timberwolf
Re: SDRangel
Post by timberwolf » 04 Jul 2018, 14:25
Thanks Drew
I appreciate the useful information. My next step is to track down a dll plug-in that decodes & displays the TS, CC & TG
Thanks again BRJ.
timberwolf
Re: SDRangel
Post by timberwolf » 14 Jul 2018, 15:49
I'm such a ****. SDRangel works perfectly. My utterly inadequate antenna was the problem ! Decoding dmr vox perfectly. There's a single line field which displays what seems, at first glance, a random string of numbers and letters. Awesomely, it sub divides into Time Slot, CC, Radio ID and Talk Group. There's even a call log screen that captures all of this essential information for you ! Typical mobile to mobile chatter is perfectly clear, intelligible and streets ahead of analogue two-way traffic. In seconds I was monitoring security watching-over today's protest march against POTUS' visit to Scotland. If you've had previous issues with DSD + and the rigmarole of installing audio cables, then get SDRangel. It does exactly what you need it to in a quick-install, fast loading package. Just don't be tempted to enter frequency, TS, CC & TG into your Radioddity RD-5r ! No point in annoying any interesting DMR user (they'll just use an encrypted vocoder that will ruin it for all listeners !)
gmham
Call Sign: 108TM154
Re: SDRangel
Post by gmham » 15 Jul 2018, 21:25
So easy enough to set up then ? Got a sdrplay rsp1 running sdr sharp or sdrplay and will check to see what spec my pc is as I believe it's got to be a certain spec for sdr angel to run x64 or whatever ? Once all installed pretty much plug and play to decode ? any advice would be great seeing as you have now successfully got it running yourself !!
P.s from the GitHub website what do I actually download for this software as I see several files ?
.... Icom IC7300 HF /6 mtr / Alinco DX70TH HF/6mtr / Kenwood TR751e 2mtr ssb... / Inrico TM7.
Ameritron ALS-600X SS HF Linear.... Cushcraft R6000 HF vertical / Hamtenna 80-10 mtr ocf dipole....... / Vine 5ele 6mtrs / Vine 10ele for 2mtrs.
Behringer xm8500 mic.
108-TM-154 - John
