"MMDVM" interfaces
troffasky
"MMDVM" interfaces
Post by troffasky » 26 Jun 2018, 09:48
Can these MMDVM interfaces be used for anything other than joining public networks like Brandmeister? If you're not familiar, it's a low-power [10mW] transceiver interface that can be hooked up to an Arduino [or similar] and passes a stream of digital audio to/from something [this is the bit I'm trying to get my head around] reachable across a network. It is not SDR so will be limited to whatever type of modulation it supports [ie, probably won't work with analogue NFM] but that means it will run from a tiny little computer.
I suppose what I am asking is, could I do something like use it as a parrot repeater? Connect a pair of them back-to-back across a network? I don't really have a use case as such, I'm just curious...
