recommend me a new antenna
Ur5by9
Super Preditor 500 by Hy-gain
Call Sign: n0call
Ur5by9
Call Sign: n0call
superstar
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Antron.
Ok ok...I was joking!!!!!!
Ur5by9
The Collector wrote:
17 Jun 2018, 09:07
Antron.
BOOTY MONSTER
Mudslinger
It would be worse.
108EH002
You can talk worldwide on CB = not 10 - 15 miles,
Freebanders know otherwise = test free.
Many of whom are amateurs = g.i.r
u.y.
27.555 Usb
BOOTY MONSTER
JAF0
Call Sign: DeltaDX10
Post by JAF0 » 27 Feb 2019, 11:00
I agree with Booty except I mod them lightly and the wind survival greatly increases.
Cut off 1/3 of the top TUBE and blitz the top ROD & ball altogether, top with a 3/8" (11mm?) solid aluminum rod about 75mm long and down-drilled to accept a shortened Wilson 5000 whip (or equivalent).
It dramatically lowers the end loading in wind plus eliminates the pathetically weak 1/8" solid aluminium top rod.
I don't deserve to be so humble
