DSD+ From a real Radio
nay27uk
Post by nay27uk » 05 Feb 2018, 14:22
Does anyone know how to get DSD+ to decode from a REAL RADIO? not an SDR.
Have my FT-857D audio going into the Audio Input on my soundcard I downloaded DSD+ but cant get it to decode for some reason.
Even downloaded the V-Cable thinking I still needed that but still the same no decode.
Does anyone know how to set DSD+ up to decode from audio from a real radio not from an SDR? (cant find any config file or anything in DSD+ folder) maybe just me being thick and missing a vital sound configuration or something but I don't think it is me.
Does DSD+ even work from a real radio or does it only work for SDR's
M6LIG / 2E0LIG / 26TM1995
Realistic Pro 2006
Panasonic DR28-LBE
Baofeng UV5R+
YAESU FT-857D
Tigersaw
Call Sign: GW6RRL
Re: DSD+ From a real Radio
Post by Tigersaw » 05 Feb 2018, 16:49
I recall doing this with a 857 in the past. You cant use the radio audio output, its not wideband enough, you have to use the output from one of the sockets, RTTY, PSK or 9600 baud digital, I'm afraid I cant remember but it was thoroughly disappointing listening to a few daleks and I didn't do it again
nay27uk
Post by nay27uk » 05 Feb 2018, 21:06
Ok tigersaw thanks for that.
It was just something I thought I would try today as I have a pc dedicated to the radio only and we have quite a lot of 2m dmr activity in Leicester.
I do have a RTL SDR on the other pc just thought it would be nice to have it decode from my radio on the dedicated radio pc.
I will wait then till I finish building my sound card data interface and try it again as that will feed audio from the data port on the radio.
Realistic Pro 2006
Panasonic DR28-LBE
Baofeng UV5R+
YAESU FT-857D
thedeerhunter270
Post by thedeerhunter270 » 06 Feb 2018, 10:49
nay27uk
Post by nay27uk » 06 Feb 2018, 11:40
Yeah thanks for that interesting info most helpful.
I believe the data interface I am making will take care of that as the data port on the radio has dedicated Audio IN and Audio OUT in the form of DATA OUT 1200bps (audio out) and DATA IN (audio IN) so I am "presuming" that they may be taped off to the radios discriminators somewhere.
Realistic Pro 2006
Panasonic DR28-LBE
Baofeng UV5R+
YAESU FT-857D
Metradio
Call Sign: G7HID
Post by Metradio » 06 Feb 2018, 12:43
AFAIK 1200bps audio out is just fixed level audio, 9600bps is discriminator audio..
Mike
nay27uk
Post by nay27uk » 06 Feb 2018, 19:44
Cheers metradio. Would that be best to solder for the interface just wondering as the instructions say use the 1200bps but if you think the 9600bps would be best I will solder my cable to use that for audio out
Realistic Pro 2006
Panasonic DR28-LBE
Baofeng UV5R+
YAESU FT-857D
Tigersaw
Call Sign: GW6RRL
Post by Tigersaw » 06 Feb 2018, 22:26
You want 9600 as I mentioned earlier.
It bypasses the squelch and de-emphasis
