Any ideas why this one only has 3kc slide each side?
Faulty 15mhz crystal? Varicap?
Cobra 148gtl dx only 3kc shift PB010
Re: Cobra 148gtl dx only 3kc shift PB010
Hi markasterix yes could it be or bad disk cap or bad inductor .etc . Check all vco components and all voltages. Gd luck n cheers.
- Call Sign: 26AT239
What mods has the radio had?
Hi Tim none but the crystal has been changed
- 13EL121
- Call Sign: 13DA121
This can happen if the oscilators are not set up correctly. With a frequency counter you should read the main oscillator and BFO frequency at the test points inside the radio. Had the same issue years ago with a SS360FM. Service manual helps.
Is the replacement a Uniden crystal ? I think I remember someone (probably Nick) saying that the Unidens have a wider "Q" than others . I would definitely start there if it isn't .
S.
- astradyne
You're correct Sammy. The aftermarket Crystals are very narrow compared to the original and will top out at around 3Khz. That would make sense in this case.cb4ever104 wrote: ↑22 Dec 2017, 11:35Is the replacement a Uniden crystal ? I think I remember someone (probably Nick) saying that the Unidens have a wider "Q" than others . I would definitely start there if it isn't .
S.
Originals are like hens teeth
