Grundig Yacht Boy 206
sickboy
Post by sickboy » 23 Nov 2017, 18:03
I picked up a yacht boy 206 up in a charity shop for the bargain price of £3.49 today. It works perfect and is in very good condition apart from one problem.
The frequency chart that you set the tuning with has distorted out of shape somehow. I've stripped it down and the offending item seems to be made from a similar type of plastic as a credit card. I tried flattening it out but it's beginning to crack.
Does anyone know where I'd likely get a replacement, or failing that a high quality scan of one so that I can print it out on photo paper?
Embrace your inner muppet !
speeddemon
Re: Grundig Yacht Boy 206
Post by speeddemon » 23 Nov 2017, 18:20
Hi sickboy. try Shortwaveham.com for parts /etc . Cheers n 73's
Tigersaw
Call Sign: GW6RRL
Post by Tigersaw » 23 Nov 2017, 18:36
I wonder if you squashed it between two pieces of glass/metal and put it in the oven at 100 or so it might recover?
No idea, just throwing out a thought
sickboy
Post by sickboy » 23 Nov 2017, 18:58
Thanks speeddemon, I had a look but it just seems to be links to ebay listings, there's no contact info or anything.
Tigersaw I think that might be the solution. I tried using my wife's steam iron with a towel over it. It looked fairly flat at first but as it cooled off it twisted out of shape a bit again. It'd probably need clamped flat until it cooled. I'll go see what I can rig up to clamp it flat while it's heated.
Thanks for the input guys
sickboy
Post by sickboy » 23 Nov 2017, 19:19
Ok, I've bolted 2 mounting brackets together with the plastic scale sandwiched between two pieces of card. I'll go bung it in the oven for 5 minutes to see if I can ruin it altogether ;)
I have the fire brigade on speed dial !
sickboy
Post by sickboy » 23 Nov 2017, 20:00
Meh... it's better but it still looks pretty mangled lol.
I'm still on the lookout for a better option if anyone has any ideas :thumbdown:
speeddemon
Post by speeddemon » 23 Nov 2017, 20:04
Hi sickboy go to grundig.com for parts and I would slowly use a heatgun/blower dyer for a min outside do not put that in a oven especially for 5mins ! Its a Toxic fumes/fire hazard.! Dont do it .never put anything plastic in a oven in indoors or outdoors.
speeddemon
Post by speeddemon » 23 Nov 2017, 20:07
Use it as is or buy a parts radio off fleabay or like said above get a replacement at grundig .com
