AOR AR-2001 scanner any good ???
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 02 Oct 2017, 20:44
how good a scanner is a old AR AR2001, have been told that this scanner is very good on civil and military air bands not very good as a scanner but very good receiver on a fixed frequency ???
bigbloke
Re: AOR AR-2001 scanner any good ???
Post by bigbloke » 03 Oct 2017, 07:41
Sounds like a fair assessment of a properly aligned one.
It only has about 30 channels and the membrane keyboard tends to wear out
All the AOR base scanners have excellent AM performance when correctly peaked / aligned
quite sensitive too - the one I used to have was better than the specs
Regards
BB
paulears
Call Sign: G4RMT
Post by paulears » 03 Oct 2017, 11:05
It was an exceptional scanner, and mine, from memory had twenty channels. It was sensitive and selective, and while the membrane keypad was simply horrible, as a scanner it was pretty decent. I wish I still had mine!
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 03 Oct 2017, 11:14
what about the AOR AR-2002 scanner is this better, worse ,or much the same but with more range than the AR-2001 ???
stratocaster
Post by stratocaster » 04 Oct 2017, 09:28
WARLOCK wrote:what about the AOR AR-2002 scanner is this better, worse ,or much the same but with more range than the AR-2001 ???
I have an AOR AR2002, It's needing some cleaning and a bit of repair done to it. However it is a very good scanner and when on AM, usually picked up the signal quicker than my Uniden BCT 15! Once I have had it repaired, it'll be used as an airband monitor. 20 channels all in however. Can't exactly remember the frequency range on it as I have packed it away, but I was impressed with it.
Post by Admiral » 04 Oct 2017, 12:23
Of the two I personally would go for the 2002 as it has a VFO-style encoder, I much prefer this than just up/down keys, and it has 800Mhz-1300Mhz if that's any use to you. On the downside the fairylight S-meter on the 2002 will send you into an epileptic fit, it's horrible.
stratocaster
Post by stratocaster » 15 Nov 2017, 10:38
Cheers Admiral! That is precisely the frequency range!
paulears
Call Sign: G4RMT
Post by paulears » 16 Nov 2017, 14:20
The membrane buttons on the 2001 were horrible compared to the 2002!
