Page 1 of 1
HDSDR problem!
Posted: 08 Jun 2017, 09:51
by Gemini4
Every time I try use HSDR it comes up with this?
Re: HDSDR problem!
Posted: 08 Jun 2017, 10:23
by Admiral
Did you do as it says? Was it working and then stopped?
ExtIO_RTL.zip
Re: HDSDR problem!
Posted: 08 Jun 2017, 19:01
by Gemini4
I did and when I do try to start it,I get this now...
Re: HDSDR problem!
Posted: 08 Jun 2017, 19:04
by Gemini4
It eventually starts but still no stations.
Re: HDSDR problem!
Posted: 08 Jun 2017, 20:43
by stanogs68
this mayhelp ,also admiral has give you the file,
viewtopic.php?f=3&t=53762
Re: HDSDR problem!
Posted: 09 Jun 2017, 16:09
by Gemini4
the file does nothing at all..it's just the same..no station pick at all.
but sdr radio picks everything up,hdsdr used to but it just hisses away now..very sad as this used to be the best one.
this happens now.
Re: HDSDR problem!
Posted: 09 Jun 2017, 16:19
by Admiral
If you've had a Windows update recently then consider running zadig again to refresh the driver.
Re: HDSDR problem!
Posted: 09 Jun 2017, 16:38
by Gemini4
Woo got it working with a few problems..I have to use LSB on 20mtrs this can't be right surely?
And volume very low.
Re: HDSDR problem!
Posted: 11 Jun 2017, 01:59
by nay27uk
20 meters is LSB you only go into USB from about 10 meters. Lower frequencies are generally LSB higher frequencies generally USB
Re: HDSDR problem!
Posted: 11 Jun 2017, 03:28
by Admiral
I don't wish to sound pedantic, but for amateur use the SSB rule-of-thumb is LSB below 10Mhz and USB above 10Mhz on HF, so 20m SSB phone would generally be USB.
Re: HDSDR problem!
Posted: 11 Jun 2017, 08:38
by nay27uk
Ah OK admiral I thought it was something like that I was forgetting 20 is 14 meg
Re: HDSDR problem!
Posted: 11 Jun 2017, 11:26
by Gemini4
Is there any way I can get it to go louder Admiral?
Re: HDSDR problem!
Posted: 11 Jun 2017, 12:18
by Admiral
Apart from the obvious volume control just below the tune frequency, or making sure you have at least one AGC on when you click the ExtIO button to the right of the tune frequency (I run with both ticked) then I'm stumped mate.
Re: HDSDR problem!
Posted: 06 Jul 2017, 09:12
by Gemini4
Got everything working sdr and now this happens!
any ideas?.
