Microphone recommendation President..
Mudslinger
Re: Microphone recommendation President..
Post by Mudslinger »
LH27 wrote:I sent a mail to Astatic and asked them about electret mic. element on the the Road Devil and they confirm that this mic use amplified electret element so it should work fine on new rig's
Not quite correct.
Modern radios with electret elements use a voltage sent up the microphone wire from the radio to power the microphone element as they work by varying capacitance. If you stick a normal mic dynamic or aftermarket power mic straight on you can damage both the mic and radio as the mic will get voltage from the radio.
On some new radios you can wire alternative mics by disconnecting the power wire inside the mic plug, but on others you may not be able to do this.
I know that on the majority of President radios and Anyclone types they will work with an alternative mic if the volateg pin is disconnected, but the Presidents in particular never seem to sound all that great.
NightProwler
Call Sign: 163TM186
Post by NightProwler »
I got 42 mics in my shack and no bugger to talk too {bnghd}
WeatherWatcher
Post by WeatherWatcher »
NightProwler wrote:I got 42 mics in my shack and no bugger to talk too {bnghd}
Big collective sigh!
LH27
Call Sign: TT
Post by LH27 »
I dismantled the original President Grant II ASC mic and controlled it up against the diagram and added some info
Lasse
mof000
Post by mof000 »
astradyne wrote:The K-PO NM-532 is a good all rounder. A great sounding power mic for less than £20!
+1 i have one of these and work well for the money.
Why did they stop making the teardrop? Was it just down to cost?
rabbiporkchop
Post by rabbiporkchop »
This guy is using the stock microphone on his President Lincoln to which has been modified for wider frequency response. I suspect changing the microphone would probably not be beneficial in his particular case.
https://youtu.be/gJaqs5n6zBY
gouda
Post by gouda »
I like my president george / Astatic 636L combination .. got lots of compliments on the way they sound together.
some radios just dont need a power mike
bc73
Post by bc73 »
I use a road devil on my Dirland 3900e and it works a treat.
_____________________________________
MM6BCF
108 TM 45
FT-747-GX.
IC-706-MK2G
Yaesu FT7
Stalker 9FDX
Dirland SS3900E
Nato 2000
Alinco DR135
Amstrad 901
73 and 51
Nothing's ever easy! {bnghd}
Big jim
Call Sign: M0czo
Post by Big jim »
I've got a a George 2 and tried sadelta base mike adonis astatic all sound the same just wondering if that got a noise limiter built in stick to stock mike
