Home made Printed circuit boards
Techquest
Call Sign: 29VLF125
Post by Techquest » 09 Mar 2016, 18:25
a few photos of my next project 0 to 250Mhz Rf sig geni pcbs.
using negative photo resist film.
Techquest AKA Jedi
Av101 Astro Plane Old Imax n Loads of Radios
Mmmmmmmmmmm ADAMS n other Presidents
radio pete
Call Sign: 26EY49G7xxx
Re: Home made Printed circuit boards
Post by radio pete » 09 Mar 2016, 20:45
they look good Ray.
theEarwigger
Call Sign: M0RZF
Post by theEarwigger » 11 Mar 2016, 16:35
Looks good for a home effort...
But why would anyone do this? Chinese PCBs are about £2 each, plated thru and resisted.
Techquest
Call Sign: 29VLF125
Post by Techquest » 11 Mar 2016, 19:06
As the thread title homebrew equipiment not true homebrew if your farming out work to third parties.
plus i can have a board for what i want in a few hours not have to wait weeks or months for it.
Techquest AKA Jedi
Mattylad
Call Sign: RDX64
Post by Mattylad » 11 Mar 2016, 20:57
If your going to home etch can I suggest that you make your gap slightly larger - looking at those pics your very likely to get dendrite growth or shorts with home etched boards so a larger track\gap is needed, you would also not need to run a scalpel between tracks.
You also have some floating (unconnected) copper i.e. under the 16 pin IC on the right, a few more in the middle. They are better off being connected to any net than floating.
I print a the drill pattern and stick it on with spray glue on a light box so its aligned - then I can drill in the right places accurately.
Then rip it off & clean the board.
Although Seedstudio do a service that gives you solder resist covered boards with vias and legend extremely cheaply - as much as I like home brew I would not consider making my own board now - the messing with Ferric and having to dispose of it etc. no more ta.
When (or if) I eventually knock up an if-10C for my Kenwood I'll be getting 10 from there for £14 and selling 9 lol
Users browsing this forum: Google Adsense [Bot] and 3 guests
