heard from 16;00 hrs today a strong carrier signal with numbers in possible Russian being spoken
this was on 5073 USB and what i heard lasted until abot 16;15 then just a silent carrier then after a few mins a tone than finally signal went off
my Russian isnt great but it was (nool) ( choterya) (visim) ( devyat) which is 0489
Note that Ukranian language is very very similar and could actually have been Ukrainian : not sure f Belorussian is the same
numbers repeated over and over and I heard an extended line of 0's in between some 0489's
the voice was not able to be known if it was a recorded voice ( like volmet) or a live voice broadcast as the numbers spoken were all sounding identical with no variation
havent heard again since
I think I heard some short pieces morse being sent but this was much much weaker signal and not for long after the voice
russian numbers broadcast today
- mikecharlie
Radio, wall of sound, coming up from my tower...
Radio, wall of sound, 24 hours of power...........!!!
- andymuza
Re: russian numbers broadcast today
Russian number stations were common placed years ago, I used to hear them all over. It was usually a female voice.
I haven't looked for or listened out for them in ages though.
If you haven't already seen this site then check it out if you're into this sort of thing.
It will give you a schedule of known transmissions.
http://priyom.org/
It takes a while to load, be patient.
http://priyom.org/
