Hey guys i have this huge ass cb antenna on the side of my house it's this one http://www.thunderpole.co.uk/base-cb-an ... -wave.html
Would there be any way in scanner's to connect that to my scanner ubc72xlt cause i think it would be amazing to have somit that high thanks.
Question haha
- Minus1
Re: Question haha
It probably has an SO239 connector on the end of the cable, so you just need an SO239 Female to BNC Male adaptor.
It'll doubtless be good for occasional foreign VHF Low dx, but no so good for UHF.
Re: Question haha
Hey well im currently using a £15 antenna small one off amazon and im wondering will it be a big improvement? andby occasional low VHF will it still pick up good Airband,Shopwatches,etc asda radios and stuff like that? cause i dont want to invest like £1.50 randomly and it to not work as good as the £15 antenna off amazon haha, i see UHF only goes 300 upwards and i normally dont really scan that upwards but yeah, what about the **** noise filtering? cause it doesnt really have a coil its just a metal pole lol.
Re: Question haha
It will be very inefficient for the services you mentioned and to be honest it will be a struggle to hear anything in the VHF UHF range as mentioned above. I tried my Gainmaster on the VHF amateur bands and the results were that I was barely able to hear them, so much so that the indoor dipole was hearing them better.
- bigpimp347
Re: Question haha
it'll work to a degree..
size is not everything when it comes to scanners, it's if they are tuned right..
a CB aerial works best on CB...oh and maybe 25 to 32mhz, after that it'll work as good as a coat hanger..
you ca buy PL-259 to BNC adaptors,
