aor AR-3000A+ HOOK UP TO A COMPUTER ? HOW TO DO
Here you can discuss Datamodes for all bands (PSK31, FT8, JS8Call, etc), Software Defined Radio topics & General Radio Software or apps
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
HELP NEEDED,just bought a aor ar3000a+now I would like to connect it up to my computer,i have got the cable coming now what software do I need ?
dcwuk
Re: aor AR-3000A+ HOOK UP TO A COMPUTER ? HOW TO DO
Post by dcwuk »
there is not much around now days AOR did have a program called Searchlight but it is not on their website now.
There are others such as:
http://www.computer-int.com/radiocom_4_5%5E2.htm
or
http://www.scancat.com/scg-win2.html
Both cost money though :( but can be used with many different radios
Or maybe here free and available :D
http://www.familie-spaans.nl/3000a.php
dcw
rayzor_uk
Post by rayzor_uk »
i use this one its better than original when you get used to it
you do have to enter your freqs
ar3000a16.zip
rayzor_uk
Post by rayzor_uk »
did you try it ????????
rayzor_uk
Post by rayzor_uk »
you just carnt help some people no feed back no thanks {bnghd}
johngarnett
Post by johngarnett »
rayzor,
As you can see I'm a returning newbie!
Just dug out my AR3000A. Firstly, I can't download your zip file ar300016.zip. Can you reattach please?
Secondly, please can you help re cable? I seem to recall I used a RS232(?) cable but now my PC has USB's!!!! plus one serial mouse port.
Any help please!!
JohnG
rayzor_uk
Post by rayzor_uk »
yes ur right on cable m8 you can get them anywere a couple of pound
file atached
johngarnett
Thanks rayzor,
I'll start hunting for a cable. I may even find something in the 'old spares store'!!
JohnG
johngarnett
Rayzor,
I wonder if you could expand on setting up the zipped prog to the AR 3000A please?
I've downloaded your file and unzipped to my PC. I can open the prog and have a control screen.
I connected my set via the RS232 socket with a connector to a usb plug, into my PC. (Should this be RS232 from set to 9pin serial on PC rear?)
I have switched the remote 'on' on set back.
I am unsure re baud rate, com port etc using a usb - help please!! The control screen remains on the writers details (German??)
Any help would be appreciated please.
Thank you
John G
rayzor_uk
Post by rayzor_uk »
its the usb always a problem when trying to establish a conection that way i ended up buying a serial port board all my scanners go through it and so no probs with usb
johngarnett
Has anyone used the prog RCON? (Receiver CONtrol) Written by Geoff Childs in 1997. Marketed by Lowes.
Is it still in exisitance?
Rayzor, OK,. Thanks for reply.
JohnG
rayzor_uk
Post by rayzor_uk »
i have another prog for 3000 but i think it was on a floppy or two i will attach it here have a try with this
rayzor_uk
Post by rayzor_uk »
http://www.transmission1.co.uk/forum/vi ... =3&t=37223
look here for info on usb convertors
Boyscoutuk
Call Sign: M3ZPE
Post by Boyscoutuk »
I know this may be a long shot but has anyone got the software I can either buy or have a copy of for the AOR AR 3000a. Also looking for the programing cable. I am now a retired pensioner and would like to use this radio better than I have done before. Thank you
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix »
WARLOCK wrote: 28 Jul 2013, 21:20 HELP NEEDED,just bought a aor ar3000a+now I would like to connect it up to my computer,i have got the cable coming now what software do I need ?
It would be nice if you could reply to those whom have taken the time to help you and let them know how you got on.... You often post new threads asking for help and then never post again on that thread. People may be less-incline to help if this becomes the norm for you.....
