Hi,
I have bourght one of these interface's in the hope of running
Some sort of Internet gateway but having a few problems in setting
It up. Everything fits into the rear of the radio ok & have plugged the
Phono leads into the USB soundcard that I have as the other soundcard
That's built into the PC is in use for other things, before I purchased this
Module I had the ct-62 leads & the psk phono leads that connected
To the pigtail lead & the rear data plug on the rear panel of the radio &
Worked spot on for tx & psk when using HRD.
But nothing when I connect this module up!! I've plugged it all in even into
The RS232 plug on the rear panel of the computer & still no indication as to it working, I was told that the L.E.D will light up when transmitting but nothing,
Is they a setup guide to setting this up as I'm clueless & seeking advise?
Digi mode interface
- Mad4radio
Digi mode interface
- Mad4radio
Re: Digi mode interface
Job done,
I figured it out:-)
I figured it out:-)
