Gritters 164.725 Turners Hill
Scanning radio frequencies in the West Midlands
Minus1
Post by Minus1 » 24 Mar 2013, 10:10
Found some Gritters on 164.725 ~114.8
Haven't figured out exactly what area they cover yet, but transmitter is at Turners Hill, Dudley. (Registered to a radio supply company not the actual user)
Code: Select all
Search tags: 164_725 TurnersHill
Minus1
Re: Gritters 164.725 Turners Hill
Post by Minus1 » 24 Mar 2013, 10:47
Callsign "Gailey Base", so probably Staffordshire Highways.
The Turners Hill transmitter will only cover the South West of Staffordshire, so there must be other transmitters further north.
Only one allocation to "CS Electronics Limited" (supplier) on 164.725, so there must be other frequencies.
This might be one, 165.3
http://spectruminfo.ofcom.org.uk/spectr ... %20licence
Transmitter at Meir Heath between Stone and Blythe Bridge
liamcarbin
Post by liamcarbin » 24 Mar 2013, 19:08
I have 162.5250 - these are gritters covering Stone, Newcastle areas in Staffordshire. No Idea where the transmiter is though.
Liam Carbin
Stoke-on-Trent
Uniden Bearcat 3500xlt
Realistic Pro-70 Hyperscan
Moonraker Skyscan Mobile Antenna
R820T Dongle ADSB Receiver
TYT-MD380
Minus1
Post by Minus1 » 25 Mar 2013, 09:17
Thanks Liam, that is the same company, transmitter also at Meir Heath
http://spectruminfo.ofcom.org.uk/spectr ... nd+licence
liamcarbin
Post by liamcarbin » 25 Mar 2013, 11:35
No problem. I presume its the same gritters on each freq? or different gritters covering different areas?
165.3 is active at the moment. But very scratchy poor signal, considering its from meir heath way. Currently talking about a farm on this freq. Using the same beeps after messages that are used on the 162.525 freq
Liam Carbin
Stoke-on-Trent
TYT-MD380
Users browsing this forum: No registered users and 0 guests
