HMP LEEDS ARMLEY
Scanning radio frequencies in Yorkshire & Lincolnshire
thelad
HMP LEEDS ARMLEY
Post by thelad » 23 Nov 2012, 22:07
Just an update HMP Leeds still Analogue on 451.8500 mhz
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
littleelvis
Call Sign: 23
Re: HMP LEEDS ARMLEY
Post by littleelvis » 09 Dec 2012, 11:22
Hi there, I am from the Morley area. Picked up some very weak and broken transmissions on this frequency 2 nights ago. Nothing special just someone needing access to block B. Just thought I would update
Rock N Roll aint dead, It's just on a coffee break.
thelad
Post by thelad » 09 Dec 2012, 11:29
Yes thats the prison, i pick it up patchy at other side of leeds.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
littleelvis
Call Sign: 23
Post by littleelvis » 21 May 2013, 17:32
Picked up the prison today. They were quarying whether a prisoner had escaped. Do they do training in this or would this of been the real thing?
thelad
Post by thelad » 21 May 2013, 18:19
god knows, would think if they had an escape they would use the airwave system but cant see them having enough sets for every warden.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
smoggy07
Post by smoggy07 » 22 May 2013, 05:53
Every now and then at random(?) (or when the numbers don`t add up) they do what`s known as a stand fast roll check where they sound the alarms and run a head count all round the jail
They send officers to set points around the fence/walls and get numbers from each wing/block or education/work place and they don`t stand down or let anyone in or out until the roll is reported correct
26TM234
Allan666
Call Sign: G0CRB
Post by Allan666 » 22 May 2013, 07:58
Around this area of 10 miles south of Birmingham.You can pick up as clear as anything,I think its Long Lartin prison Nr Redditch /Bromsgrove ..In actual fact its signal is so strong i normally keep it locked out.
littleelvis
Call Sign: 23
Post by littleelvis » 22 May 2013, 10:57
ahh I see...thank you guys
littleelvis
Call Sign: 23
Post by littleelvis » 24 May 2013, 09:39
A lot of activity this morning from Armley including at least 2 fire alarm activations
bigtee
Post by bigtee » 23 Jul 2013, 07:50
Busy this morning a strong signal 5-9 but i do use a external antenna.
Up in Morley.
thelad
Post by thelad » 26 Jul 2013, 18:48
tone CTCSS 131.8
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
thelad
Post by thelad » 26 Feb 2017, 16:25
seems to have gone dead now, moved to full Tetra or just moved bands?
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
