All UK Shopwatch Frequencies 2012
- houstonboyuk
Re: All UK Shopwatch Frequencies 2012
ok thank you anyway my friend. your a gent
Thanks for reading.
- houstonboyuk
should I put the base rx as my radios tx and base tx as my radios rx?
Thanks for reading.
Not a great idea as if you accidentally key up the rig you'll be transmitting into the shopwatch repeater. Also I would imagine if you get caught with a transceiver set up to TX on the shopwatch frequencies you'll be in considerably more trouble than you would if it was a receive only scanner. At the very least I'd program one of the PMR446 channels into the TX frequency instead.houstonboyuk wrote:should I put the base rx as my radios tx and base tx as my radios rx?
Tom
- houstonboyuk
i understand my getting into trouble i just wondered if that was stopping me hearing anything.
Thanks for reading.
I can hear Shopwatch in Lincoln just can't make out what they are saying. sounds scrambled.houstonboyuk wrote:thanks liam, im over in Lincoln at the moment, can you pick up lincolns shopwatch at all or can anyone on this forum pick lincoln shopwatch up? if you can ill program my radios into lincolns frequency and have a listen. if i can here them then this my determine the reason to y i cant hear gainsborough. (wrong frequency)
Ham: Yaesu FT-100D, Yaesu FC-20.
CB: KPO DX 5000(V4), TTI-TCB-880.
Scanner: Uniden Bearcat UBC 3500XLT, Alinco DJ-X3, Yupiteru MVT-7100.
PMR 446: Binatone Terrain 550.
26-TM-2407
26-TM-2407
- houstonboyuk
i cant here anything any suggestion to why?
Thanks for reading.
- liamcarbin
How far away are you from the city centre? I'm just down the road and can pick shopwatch/pubwatch up on the stock antenna that my scanner came with. Maybe you are not close enough?houstonboyuk wrote:i cant here anything any suggestion to why?
Liam Carbin
Stoke-on-Trent
Uniden Bearcat 3500xlt
Realistic Pro-70 Hyperscan
Moonraker Skyscan Mobile Antenna
R820T Dongle ADSB Receiver
TYT-MD380
Stoke-on-Trent
TYT-MD380
Lincoln shopwatch 453.0625mhz CTCSS 67.0 NFM.
I'm up near the prison/hospital and they come through really strong off just a rubber duck.
Dunno if it is digital or scramble? Anyone got a link to what digital sounds like on an analogue scanner?
26-TM-2407
26-TM-2407
- houstonboyuk
Hi Im near Dixon street at the moment. Im guesing Im not programming it right. Do you know how to program these f22 radios?
Thanks for reading.
You would hear them from that location no problem on that Freq i gave above.
You need a cable and software to program them i think.
26-TM-2407
26-TM-2407
- houstonboyuk
Thanks scanking, ive got the cable and software but I dont fully understand the software.
Thanks for reading.
houstonboyuk wrote:Thanks scanking, ive got the cable and software but I dont fully understand the software.
Can't help you there as i know nothing about those radio's LOL
Been monitoring shopwatch Lincoln Freq. all morning from 9.30am and its not been very busy a few radio checks thats about it not very exciting really.
26-TM-2407
26-TM-2407
- houstonboyuk
i did hear some a few minutes ago but it sounded scrambled, ive turned that inversion thing on to see if that works
Thanks for reading.
Sounds like it is working.houstonboyuk wrote:i did hear some a few minutes ago but it sounded scrambled, ive turned that inversion thing on to see if that works
Managed to decode via pc so its deffo voice inversion.
Software had crashed thats why it was quiet LOL
Did you just hear them about the swan on Altham Terrace.
26-TM-2407
26-TM-2407
- houstonboyuk
no it still sounds scrambled. i dont know how to sort it out lol
Thanks for reading.
