London?
- radiosification
London?
Is this the right forum to post in for London?
- Banned
- Mark-in-Essex
Re: London?
Seem to remember a couple of big CB stations from Barnet a few years ago....
- radiosification
Re: London?
oh right good. I've got some frequencies for buses. You can hear the control but not the buses reponding as it must be a trunked system and I don't know the frequencies for the buses.
The control frequencies are:
139.755
139.995
139.645
139.870
139.755
139.995
139.645
139.870
- radiosification
Re: London?
Do you know what frequencies/channels they were on?Mark-in-Essex wrote:Seem to remember a couple of big CB stations from Barnet a few years ago....
- Minus1
Re: London?
(Better late than never) You'll find them 8.5 Mhz higher in the 148.00625-148.99375 range.bben95 wrote:oh right good. I've got some frequencies for buses. You can hear the control but not the buses reponding as it must be a trunked system and I don't know the frequencies for the buses.
139.755
139.995
139.645
139.870
I just picked up some of the 139 transmissions in Birmingham, must be a bit of a lift on.
- radiosification
Re: London?
Wow thats cool. Are they all exactly 8.5Mhz above the channels they are talking to? Or were you just saying in general they are about 8.5Mhz up?Minus1 wrote:(Better late than never) You'll find them 8.5 Mhz higher in the 148.00625-148.99375 range.bben95 wrote:oh right good. I've got some frequencies for buses. You can hear the control but not the buses reponding as it must be a trunked system and I don't know the frequencies for the buses.
139.755
139.995
139.645
139.870
I just heard a bus when searching the range.
The ones you heard could have been from somewhere else, not the london ones, as I've heard the others operating on the same frequencies.
Re: London?
That's just a few of them and those frequencies are slightly off, they are actually on 6.25KHz ofsets.Minus1 wrote:bben95 wrote:oh right good. I've got some frequencies for buses. You can hear the control but not the buses reponding as it must be a trunked system and I don't know the frequencies for the buses.
139.755
139.995
139.645
139.870
There are a load more base channels in 139.5-140.5MHz.
Just google ibus for the full list of base frequencies and the transmitter locations.
- radiosification
Re: London?
Thanks, will do.normal wrote:That's just a few of them and those frequencies are slightly off, they are actually on 6.25KHz ofsets.Minus1 wrote:bben95 wrote:oh right good. I've got some frequencies for buses. You can hear the control but not the buses reponding as it must be a trunked system and I don't know the frequencies for the buses.
139.755
139.995
139.645
139.870
So are the bus to base frequencies not related to the frequency of the base - do you just have to guess which are which by listening to the conversations?
Do you know also if they in 25Khz wide fm or 12.5
Re: London?
If you bother to google ibus frequencies you will this radioreference page and with the simplest of mathematics you can see some of the channels are 12.5KHz apart.Do you know also if they in 25Khz wide fm or 12.5
The current system is only a few years old. 12.5KHz maximum per channel has been standard in the UK for a long time.
- radiosification
Re: London?
Yes I assumed they would be but when I put one of the frequencies in as narrow fm it sounded distorted so I changed it back to 25Khz and it sounded normal again.normal wrote:If you bother to google ibus frequencies you will this radioreference page and with the simplest of mathematics you can see some of the channels are 12.5KHz apart.Do you know also if they in 25Khz wide fm or 12.5
I did go to that site before and I have the frequencies from there in my scanner already.
- 26LM3RX
Re: London?
googled ibus and i got nowere..normal wrote:That's just a few of them and those frequencies are slightly off, they are actually on 6.25KHz ofsets.Minus1 wrote:bben95 wrote:oh right good. I've got some frequencies for buses. You can hear the control but not the buses reponding as it must be a trunked system and I don't know the frequencies for the buses.
139.755
139.995
139.645
139.870
does anyone have the bus frequencys for the buses. not just the controllers base ect,..
i live near woolwich south east london, loads of buses. really wana listen in
Danny - 108/26LM3RX
Uniden100
Vero Uv-X4
Yaesu VX-6R
Superstar 3900
Uniden100
Vero Uv-X4
Yaesu VX-6R
Superstar 3900
- Minus1
Re: London?
The buses transmit 8.5 MHz higher than the base, in the 148.00625 to 148.99375 range, NFM.
