Hi all.
havent been posting much recently because ive been away but now im back and the FRG is up and running. To cut a long story short im disappointed with my naff long wire antenna. the first week i had the frog was fantastic and heard loads of international contacts but i just cant seem to hear anything now theres just too much noise around and i dont have the space or money for a better antenna. So, i think i might sell the FRG and get a scanner instead that i can use at airshows etc.
So how much could i ask for an FRG8800. immaculate condition, works perfectly. in original box with manual and fitted with the optional VHF card.
also the FRT7700 tuner with manual. also works perfectly.
-Paul
Selling The Frog?
- 5thElement
Re: Selling The Frog?
Can't answer your question but check ebay and see what they're going for there, you can run a search on items that have allready ended as well
2E0XGA
- dcwuk
Last one i saw on ebay went for £200 for the receiver only. http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0059934378
I am sorry that you have not had a lot of luck with your longwire and not knowing how much room you have or your environment i wonder if you have considered a simple loop aerial such has this one?
http://www.iw5edi.com/ham-radio/?hf-rec ... antenna,51
cheers
cheers
