Evening folk, new to here.
Hamming it mostly on 2m, take part in UKAC when the weather allows, do a bit of SOTA. Some HF, I get my arm twisted to do HF contesting occasionally.
A bit of PMR446 DXing, and do the odd restoration of ancient kit just to keep my skills honed.
Some 11m/CB gear ancient and modern, FT817, FT450D, FT950, FT2900 and a collection of handhelds.
Current work gets me all over the UK mainland, occasionally with overnight stays, where I can find that the portable kit has "accidentally" found its way into the works vehicle.
Hello from Yorkshire
- Call Sign: M0DCD
- Call Sign: G0CRB
Re: Hello from Yorkshire
Hi Andy and welcome.
- MrWeetabix
- Admin
- Call Sign: 26TM175
Welcome to the forum. Occasionally do the UKAC contests myself, more to just give points away than play the game that is, but who knows, might get you in the log one day.
Welcome to TM1
Welcome to TM1
