KL400
NightProwler
Call Sign: 163TM186
KL400
Post by NightProwler »
I know this amp has been discussed before but I thought I mention what mine is doing. 10 watts in on FM with the amp on stage 6 gives me 160 watts, 20 watts in on SSB gives me 160 watts too. This was tested using an AV600 meter with a 250 watt dummy load. Now I know power is always exaggerated but I did expect a bit more on SSB. Oh well.
Re: KL400
Post by ch25 »
PEP or AVG?
NightProwler
Call Sign: 163TM186
Re: KL400
PEP
Re: KL400
Post by ch25 »
Measure voltage on amp board after the fuses and on power supply terminals under FM 160W load.
What is the result?
p.s. on the other hand 400W from 2 pills is not possible :)
NightProwler
Call Sign: 163TM186
Re: KL400
To be honest Chris I can't really be arsed to open it. I know I would never see 400W from it but I thought it might do a little more than it is. Damn cheap amplifiers.
Re: KL400
Post by ch25 »
I'll tell you a secret. 400W it takes from wall wart :)
Anyway voltage drop is worth checking. You could squeeze a little more watts out of it.
