Hi All..
Got hold of a SOMMERKAMP TS 789 Dx variant of this radio, I’m finding the Vco is taking afew seconds to lock whether I’m changing frequency or indeed mode, also on tx it “wobbles” abit on the initial key up. Believe it’s abit of a known fault with theses radios. Question is, is there any fix? or a better replacement Vco?
Much thanks for any help
RANGER 2900, TS 789 DX,GALAXY URANUS Vco..
- Raverrst
- Call Sign: 26LW29
Radios, radio!!
- cb4ever104
Re: RANGER 2900, TS 789 DX,GALAXY URANUS Vco..
Hi . Thought Chris answered this on FB . Did it not resolve this issue , as it looked like the exact same issue that you were having .
- Raverrst
- Call Sign: 26LW29
Hi, yes it’s greatly improved things There is a much more in-depth fix on “Cb Tricks” under Ranger 2900 but as said Chris’s find fix of Changing Resistor R-124 from 47k to a 10ohm then setting Vco voltage to 2volts on 28mhz for anyone Requiring this info in the future, has worked a treat..cb4ever104 wrote: ↑05 Feb 2024, 14:14 Hi . Thought Chris answered this on FB . Did it not resolve this issue , as it looked like the exact same issue that you were having .
Radios, radio!!
- cb4ever104
Great . Thanks for confirming thisRaverrst wrote: ↑08 Feb 2024, 23:25Hi, yes it’s greatly improved things There is a much more in-depth fix on “Cb Tricks” under Ranger 2900 but as said Chris’s find fix of Changing Resistor R-124 from 47k to a 10ohm then setting Vco voltage to 2volts on 28mhz for anyone Requiring this info in the future, has worked a treat..cb4ever104 wrote: ↑05 Feb 2024, 14:14 Hi . Thought Chris answered this on FB . Did it not resolve this issue , as it looked like the exact same issue that you were having .
