Modification channels COBRA 148GTL
electronicsmachine
Call Sign: 1TM129
Post by electronicsmachine »
Hello,
I would like to know the expansion channels and other modification for the COBRA GTL 148 ? many thanks...... :thumbup:
1 TM 129 -------- TANGO MIKE DX 11 METER GROUP ITALY Location: BRINDISI (SOUTH ITALY )-------------
Equipment Radio C.B. : President Jackson + Mic. Sadelta Echo Master Plus+ Ant. Lemm Vertical M5 5/8
Re: Modification channels COBRA 148GTL
Post by ch25 »
Digimax
cb4ever104
Post by cb4ever104 »
One of the members on here (Black Spirit) does a small , inexpensive expansion pcb to add the HI band , with +10khz . To be honest that's enough for me . If you require something more intricate , then you'll need to spend more .
Sammy
Auldgeek
Call Sign: GM0BRJ
Post by Auldgeek »
I've had my 148 GTL modified by Black Spirit, as per above post. That gives me mids, high and the UK 40. Added FM too.
There's various different add on boards available to expand the 148, such as Channel King and DigiMax. Lescomm do several expansion boards but all quite expensive. For me, Nick's PIC chip was easy and inexpensive.
You need to watch the bandwidth, as the 148 performance will drop significantly at either end should you select to add several bands. Mine is spot on but essentially, it's only covering 1Mhz from 26.965.
Auldgeek - Drew
dt307
Call Sign: 163dt307
Post by dt307 »
and you got the pin 10 pll trick that will give you the ssb portion of 10m
163dt307-chris
― Albert Einstein
Blackolive
Call Sign: G4WCS
Post by Blackolive »
dt307 wrote: 01 Sep 2019, 00:18 and you got the pin 10 pll trick that will give you the ssb portion of 10m
Will this work on a gtl150 please ?
cb4ever104
Blackolive wrote: 04 Sep 2019, 20:52 Will this work on a gtl150 please ?
No , sorry . This mod is only for the MB8719 PLL . Yours has the PLL02A .
Sammy
Blackolive
Call Sign: G4WCS
Thanks 👍
163TM847
Post by 163TM847 »
If you isolate pin 9 of the PLLO2A while on Mid band you should get 27.605 to 28.045 so when switching to High band you should get 28.055 to 28.495 [or thereabouts] but you will more than likely need to lock VCO and trim RX/TX tuning stages.
Blackolive
Call Sign: G4WCS
Black Spirit wrote: 05 Sep 2019, 11:48
Just been cleaning the pcb up, its had some recapping and work done and some messy soldering and found this.
Looks like its had the mod done at some point. This is worse than buggering about with old cars. It was sold as working (spares only), transmitting ok but beggar all on receieve, going to rework some dodgy joints round regulator and dc switch transistors then check a few dc voltages
Marlin45
Call Sign: 163CT266
Post by Marlin45 »
Mr Half-Arse and his happy hot knife has been there before? I guess the plus side is most of the tracks are intact and there is no evidence over an oversized hot chisel lifting the tracks?
'I'm a rider at the gates of dawn, and I take no prisoners' - Rik (The Young Ones - 1982)
electronicsmachine
Call Sign: 1TM129
cb4ever104 wrote: 31 Aug 2019, 09:39 One of the members on here (Black Spirit) does a small , inexpensive expansion pcb to add the HI band , with +10khz . To be honest that's enough for me . If you require something more intricate , then you'll need to spend more .
Sammy
sorry I can't contact black spirit.....can you help me ;) for info modified....
cb4ever104
electronicsmachine wrote: 21 Jan 2024, 15:01
Sammy
Send a message to user "163TM847"
electronicsmachine
Call Sign: 1TM129
cb4ever104 wrote: 22 Jan 2024, 17:38
Sammy
Thank you
