sounds like the bp or that area.i have a lot of freqs for the bp and that area as i live just up the road.i could post them if anyone wants the freqsGnosticBhoy wrote:Does anyone from Central Scotland know what this frequency is : 456.675Mhz ?
I listen to it from time to time and the chatter is about valves, pressure, and tower is mentioned. Is it a sewer works ?
Scottish Frequencies - 446 - 453 mhz
Re: Scottish Frequencies - 446 - 453 mhz
- Call Sign: Bravo31012
i have also heard a lot of chat on this frequency and i think its grangemouth because there is also chat about the times of ships coming in to moor. if you still use this site it would be great if you could post the other bp and that area frequencies
- oldpink
456.675 is the Forge freq but its Encrypted
I hear Radio Waves in my head
CRT SS 6900 Fully modded Export setup programmable
Cobra 148 GTL DX Mk 2
Alan 9001 26 - 30.190 multi band
SDRPlay RSP1A x2 with a Create 5310 on a rotator and Discone for general
108-TM-046
108-TM-046
446.1625 Seems to be container terminal in Greenock. Frequent container ref numbers and some choice language.
The forge one I'm waiting on my digital dmr scanner arriving will it pickup the forge on digital
- thelad
Would appear to be Encrypted so it will pick it up but you won't be able to understand the audio.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Is there any way on this digital dmr scanner to decode the encryption or anything you can buy for it
- Metradio
- Call Sign: G7HID
What DMR scanner are you getting ?
Mike
- thelad
If its DMR Encryption then no.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Hi Mike unideen sds100e DMS Scanner it gave me the option to pay for nxdn and pro voice on it but I just went with the DMR one without nxdn or pro voice should I have went for all ordered from radioworld
I'm sure the fort is 456.6750 but the parkhead forge yousd to be 165.2125 are you sure the encrypted one is dedinetely the forge and not the fort ?
