QRM from led street lighting issue.
- Call Sign: 45
I'd like you help please on a big problem .
qrm 6/7s point of noise when street led lighting is on .
Without doubt this is the reason and it just wipes any radio use out ,it's just impossible to hear anything but crap.
Has anyone had this problem and how can it be removed if at all.
Best advise and ideas please.
- Buick Mackane
- Moderator
Re: QRM from led street lighting issue.
If you don't have an amateur radio license then theres not much you can do about it other than a big dirty air rifle, If you do have an amateur radio license and the noise is also present on the amateur radio bands, Then you can report it to ofcom,
Looky here
https://www.ukqrm.org.uk/finding.php
Working any sort of radio station from home is getting tougher & tougher, Everything seems to produce noise these days, The biggest offenders are junk chinese electronics, Switch mode power supplies etc etc etc
Looky here
- Auldgeek
- Call Sign: GM0BRJ
You won't need to use Awfulcom if it's coming from street lighting. Assuming it's on what's known as an adopted street (not private), call the local Council and report it as faulty. If you know the column number (usually on the pole), include that info when reporting it.
Better still, ask to have one of the lighting Inspectors call you and you can discuss the matter further. They are usually quite helpful.
Best of luck. QRM is rapidly killing our hobby unfortunately but this sounds a fairly simple fix.
Auldgeek - Drew
- Auldgeek
- Call Sign: GM0BRJ
Aye, you're the biggest offender. You buy so much Chinese junk from Long Dong's backstreet sweatshop sister "Minging Ling", they'll be introducing a new Mackane import tax as part of that fluckin Blexit!Buick Mackane wrote: ↑11 Mar 2019, 17:35 If you The biggest offenders are junk chinese electronics, Switch mode power supplies etc etc etc
Auldgeek - Drew
I fitted LED reversing lights instead of bulbs (they are a lot brighter to be honest), but the interference from them wipes out my wireless reversing camera. I'm not sure if they're interfering with the reversing sensors on the back bumper too as that started playing up last year too (might be a sensor gone though).
I think they're sometimes more hassle than they're worth.
- Buick Mackane
- Moderator
Here we go Another auld G-call flexing his muscles, Contradict me again and you can kiss goodbye to the sporadic E season on 6m, I'll key you out big time, ya walopper that ya arekilimax wrote: ↑11 Mar 2019, 19:01 You won't need to use Awfulcom if it's coming from street lighting. Assuming it's on what's known as an adopted street (not private), call the local Council and report it as faulty. If you know the column number (usually on the pole), include that info when reporting it.
Good advice drew, Never knew that, Hopefully it will be as easy as you make it sound, But alas in my case i'm stuck with it, New heating system that the council installed a few years ago causes nothing but grief radiowise, I never got it installed as i couldn't be assed with them wrecking my house for a week whilst they were installing it, But both neighbours either side have it,
Its called air to water heating, Big fans mounted outside the houses, As well as causing air bourne QRM it also dirties the mains supply, But a few chokes have cleared up that side of it,
You'd think these things would be EMC Checked before being pressed into service, If it was causing problems with TV Reception or commercial radio they'd have them out quicker than a priest from a brothel raid,
Iv'e heard you like a wee bit of long dong yourself Aye and theres more oriental chepo delights arriving this week, I think i'm turning japanese, I really think so
- Auldgeek
- Call Sign: GM0BRJ
Aye, here we go. Jealousy gets you nowhere ya 3rd rate oriental sh1te worshiper!Buick Mackane wrote: ↑11 Mar 2019, 19:53
If it's a Council maintained lighting column, it should be relatively straightforward.Buick Mackane wrote: ↑11 Mar 2019, 19:53
No chance. I leave that kind of entertainment to Minging Lings next door neigbour, Larry Long Love.Buick Mackane wrote: ↑11 Mar 2019, 19:53
Auldgeek - Drew
- Call Sign: 45
Thank you for the advices and direction to try. Be very sad if the hobby for many dies due to these type of interferences .
Thank you again
Thank you again
It's a shame you can't simply hook up a decent amplifier and blow things up or interfere with them like you seemed to be able to do in the old days.
Tv's completely wiped out, petrol pumps slowed down, radio controlled aircraft downed etc etc.
Sticking 100watts through your radio and blowing all those LEDs to kingdom come would be a nice little outcome
^^ 100w is far too low to cause damage.......the street lights still work at my 20
27.555 Usb
27.555 Usb
- Call Sign: Lemmy
Airgun is way better.
I get hammered with man made noise from neighbour's security lights.............at least its getting lighter at nights,so I can hear more the lighter it getsoriginal45 wrote: ↑13 Mar 2019, 10:01 Thank you for the advices and direction to try. Be very sad if the hobby for many dies due to these type of interferences .
Thank you again
27.555 Usb
27.555 Usb
- Call Sign: 45
Yes I am too.very annoying as I made contact tonight on I think a Leicester ssb 27,2550 net but had to clear due to noise.
My neighbour has led security lights as I do but I turn mine off .
I may just blow theirs off .
Spoiling our fun.
I can see it killing the hobby unless you go portable .
Sad days
Spoiling our fun.
Sad days
My parents old heating thermostat/timer used to wipe my radios out, which was a real mystery to us. "Static" would build up every 10 minutes or so and oclvertake everything but the strongest 30+ signals. Then it would suddenly disappear...until a little while later. I used to have to ask people to hang on for 30 seconds until it passed.
About 3 years down the line, the heating went kaput, the then faulty thermostat was changed and Voila! peace on the channels at last. If only I'd known back then it was so easy to remedy.
