EuroCB EA50 alignment
andrew30
Call Sign: 329TM001
Post by andrew30 » 04 Nov 2018, 06:32
Hi,
I purchased cheap used EA50, it's working, but only drawing about 2A from 12V supply (4W input).
I took it apart and tested the C1969 transistors with my DMM and both appears to be working, so it might be a problem with biasing.
Quick glimpse at the schematic reveals variable capacitor C9, which I believe is responsible for biasing - but being a young player in PCB, I'd rather have that confirmed. :D
Specs list 7A draw to be standard, but in on the schematic there's 5A.
Schematic: http://www.cbradio.cz/doc/_Other/Zesilo ... schema.pdf
Specs: http://www.cbradio.cz/doc/_Other/Zesilo ... 0/info.pdf
Or is the problem somewhere else?
dt307
Call Sign: 163dt307
Re: EuroCB EA50 alignment
Post by dt307 » 07 Nov 2018, 21:09
this is a class c design and the bias is controlled by r2
c11 for output matching tune for max output ....... connect a power meter and a dummy load to amp
c9 is for input matching tune for lowest swr .....a swr meter between the amp and radio and a dummy load to amp
163dt307-chris
― Albert Einstein
