SDRangel
- stanogs68
- gmham
- Call Sign: 108TM154
Re: SDRangel
will pm you a link mate, you still having trouble with the github download ?
in all honesty mate and I am not being funny but I think you may struggle once you get the app open its a bit off a nightmare. persoanaly would get the other TM member to teamviewer to your pc to set it up for you, I have been at it for a week or two and still struggling !
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- gmham
Re: SDRangel
PM sent mate !
" Radiogaga " get out the pub mate we need you !!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- stanogs68
Re: SDRangel
this sounds like a headbanger ,your right mate get someone with team viewer who has a bleeding clue
love your familly
- gmham
Re: SDRangel
Yep mate as I say personally would wait as if your like me you will just frustrate yourself and end up forgetting it all trust me !
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- radiogaga
- Call Sign: 26TM399
Re: SDRangel
Hi... are you about tomorrow and do you have teamviewer or AnyDesk (latter preferred) could help tomorrow morning if you like.... wish it was the pub!
30TM399 Northern Costa Blanca
- gmham
Re: SDRangel
Not sure if it's me or stanogs68 mate ? but if poss could I maybe take you up on your kind TeamViewer offer to set up the dmr side off things for me ? . As I say have the programme installed and working just need a hand to configure the settings to decode dmr. No probs to waitt as appreciate the other chap was the one asking for assistance first !!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- radiogaga
Re: SDRangel
No worries. I’m in Spain so internet can be a bit iffy but I’ll give you a shout tomorrow
AnyDesk seems more stable for me too, rather than TeamViewer.
- gmham
Re: SDRangel
Okay no worries mate easy enough to download and use ie Do I have to set up anything this end or just give you my access details for you to connect it ? Will await your pm tomorrow. Thanks again appreciate that.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- radiogaga
Re: SDRangel
No, just give me the code later. I have to do the chores first as set by the missis.
Just a couple of things you can try first which could be easy wins.
1. Make sure you are using a USB 2 port. USB3 don't work!
2. Make sure you are seeing your dongle as a device. I guess broadcast WFM is fine in SDRAngel AND SDRsharp? Not all dongles are supported.
3. I think it's only simplex that you'll be able to receive. Unfortunately I can run it up and use it but even with some great lift it isn't going to hop 1000km to me here. I don't think trunked is supported.
From 17 minutes in the youtube link is worth a look
Catch you later
Catch you later
- gmham
Re: SDRangel
Good morning to you and thanks for your reply. No as I say have everything working on sdrangel ie receiving fm broadcast / fm narrow band. Am etc etc it's just getting the thing to decode some dmr. Just a bit stuck with all the settings that's what I am saying you managed to decode dmr with it yourself ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- radiogaga
Re: SDRangel
Yes, decoded simplex fine in the UK with Linux. I'm in Spain at the moment so therefore can do no more than install and test as I do not have my DMR handie with me. Drop me a PM when you are available on AnyDesk and include the code and we'll take a look.
- stanogs68
- gmham
Re: SDRangel
No sorry mate got told off from the wife that I was hidden away in that room again !
Radiogaga - okay mate yep will pm you now. the local shopwatch freq is on 453.150 so if you could just set everything up for me for dmr decoding then that would be great. not sure if I have my input / output is correct within the audio settings off sdrangel as showing vb audio for input that was from running sdr#/ the sound is comming out okay from fm broadcast etc so guess the sound output being my speakers is correct ? if you could take a look at these settings.. appreciatte taht.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- radiogaga
Re: SDRangel
Waiting on your acceptance of the AnyDesk. I suspect it will be trunked??
