Open Golf Carnoustie 2018
I know its not due to start till July. But the build up is already on. Currently have the car parking / Security using 163.5625 CC1 TS2
Re: Open Golf Carnoustie 2018
I’ve stayed at the hotel a few times and hotel staff use 459.125 analog
I’m not sure if that’s the input of a repeater or simplex.
But I would guess simplex as not a massive area to cover.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
455.5750
455.7750
456.0250
455.7500
455.5000
456.0500
455.7250
455.8125
455.8500
455.6250
455.4875
455.6000
455.6500
455.5500
All dmr according to Ofcom
455.7750
456.0250
455.7500
455.5000
456.0500
455.7250
455.8125
455.8500
455.6250
455.4875
455.6000
455.6500
455.5500
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Plus vhf dmr
163-164 MHz
163-164 MHz
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Active today is 163575 Slot 1 CC 7 - Marshall Control
Also 163.400 Slot2 CC6 - CSP Car Parking
Also active on the 16/ 17th -
158.7875 Slot 1 CC14
163.900 Slot 2 CC9
159.400 Slot 1 CC9
163.900 Slot 2 CC9
159.400 Slot 1 CC9
Today's lucky numbers [so far]
163.450 Slot 1 CC4 TG4700 - R&A control
163.450 Slot 2 CC4 TG1700 - unknown but not parkway
and update on
163.575 Slot 1 CC7 TG5300 - Marshall Control
163.400 Slot 2 CC6 TG4600 - CSP Car parks
163.5625 Slot 1 CC1 TG1000 - Maintenance Crews
159.400 Slot 1 CC 9 TG1000 - ??
and update on
- Call Sign: G4RMT
Outside broadcast vehicles much more entertaining and all analogue FM - loads of frequencies, most continuous carrier and you need to search in 441 - 446-455-457-461 which are where the main OB legal tx channels are - 441 is usually simplex. The rest go through the comms matrix, so will be either engineering, production or occasionally sound and logistics.
Used to listen to the BBC down in the lower NFM freqs. Im not actually in Carnoustie. But picking theses up across the water in St Andrews
Currently listening to
163.850 Slot 1 CC 2 TG5125 - Litter picking squad / Sweeping squad
- AshtonMobileScanner
- Call Sign: 26TM931
Mentioning talkgroups will only force the golf teams to go encrypted!
Motorola UHF DP3600,
Golden One 1907,
Baofeng UV5RA+,
Diamond RH771 Antenna,
UHF Stubby Antenna,
Diamond X-30 Antenna,
MASS SPS 250 MK2.
(Monitor All Channels)
- Call Sign: G4RMT
Encrypted litter picking squads? That's actually funny to think you spend time searching for digital frequencies, discovering the talk groups and colour codes to discover ......... rubbish~!
The only thing that would force encryption is folk keying up and jamming the channels
As long as folk behave then it should be ok
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Not round Manchester, as soon as frequencies with full details (CC, Group and Slot) appear online they disappear within weeks. Its looking that way up and down the country.
Golden One 1907,
Baofeng UV5RA+,
UHF Stubby Antenna,
MASS SPS 250 MK2.
- thelad
Litter picking
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
