trying to find a signal meter for a murphy CBH 1500 if any one knows or has one they might want to part with.
cheers
matt
Signal meter for Murphy CBH 1500
- Call Sign: M0VPL
C.B got me into radio. Ham radio followed later. I enjoy it all. pride and joy a FTdx9000D. FTdx3000D TS2000X 23cm
DR.E 400 DV 2m/70cm TR-751 2m wouxun KG-UV950P 4 mtrs FT-840 CB Superstar 360fm (got to be uniden)
- 163TM847
Re: Signal meter for Murphy CBH 1500
The decal backplate normally falls off in these trapping the needles so make sure its stuck back down properly, This can be a bit fiddly, If the meter is well and truly no good i may have one in some bits up the attic somewhere, But no decal back plate,I would have to find it and check its still ok.
- Call Sign: M0VPL
Hi Nick
I would apreciate it if you could find one, i have a good back plate, but the meter itself is no good, completely missing one needle and the other is bent like a banana with what looks like a fine copper spring hanging out of it.
thanks for the reply
matt
matt
- 163TM847
I found it but i got it wrong, decal plate is on it but missing plastic glass cover, so as long as the one you have is ok then it should be fine.
- Call Sign: M0VPL
hey thats great nick, i have the glass cover, PM what you want for it and and postage, i will get the funds over to you.
Thats great news, this 1500 is in good condition but seems someone had a go at the meter back plate fix and really damaged the meter itself.
Thanks nick your a star!
- astradyne
- Moderator
Another radio saved.dipstick wrote: ↑21 Jun 2018, 17:50 hey thats great nick, i have the glass cover, PM what you want for it and and postage, i will get the funds over to you.
- Call Sign: M0VPL
I hope so, as its in good condition, thanks to nick it should be back to its former glory!
