hy~gain clr2
- superstar
hy~gain clr2
after 3 years up on the stack the new old stock clr2’s swr went into the red, went up yesterday evening to have a look and part of it has broken at the base, looks as though it’s been eaten away by corrosive smoke from the fires we have in winter, the same thing happened to the starduster i had up, but i just put it down to salt air living close to the sea, ill put some pics up of the damage when i get it down, ive got some other stuff to put up though, hygain penetrator 500, avanti astroplane, shakespeare big stick, vector 4000, so off air temporarily
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Cb handle
- prettypolly
- Call Sign: 26FB185
Re: hy~gain clr2
I sold mine within a week gaining a handsome profit
- kilimax
- Call Sign: GM0BRJ
Re: hy~gain clr2
So you will have made "Hy-Gain" then?
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
I've changed radios that many times, I've forgotten what I have
- superstar
Re: hy~gain clr2
here’s what’s happened
Cb handle
Cb handle
- The Collector
Re: hy~gain clr2
Maybe metal fatigue helped that along? Too-ing and fro-ing in the wind over a couple of years may have been enough to weaken it and corrosion compounded it.
Whack up the Ham Int. Hy-Power I sold you! That will be a sight
- superstar
Re: hy~gain clr2
oh yeah i forgot about that one, its under the bed
Cb handle
Cb handle
- superstar
Re: hy~gain clr2
clr2 spares or repairs anyone?
Cb handle
Cb handle
- superstar
Re: hy~gain clr2
i filmed the taking down in time lapse, check it out
https://youtu.be/vsKALudZLF8
Cb handle
Cb handle
- Ur5by9
Re: hy~gain clr2
How do you rate this antenna ?
I have a Sirio 827 and looking for something different.
Super penetrator 500 also on the short list
- superstar
Re: hy~gain clr2
works ace, but obviously there’s a weak point,
Cb handle
Cb handle
- superstar
Re: hy~gain clr2
i’ll see if i can bung it up, should look pretty impressive up on the stackThe Collector wrote: ↑14 Jun 2018, 18:39Maybe metal fatigue helped that along? Too-ing and fro-ing in the wind over a couple of years may have been enough to weaken it and corrosion compounded it.
Whack up the Ham Int. Hy-Power I sold you! That will be a sight![]()
Cb handle
Cb handle
- Ur5by9
Re: hy~gain clr2
Look forward to seeing fly high - don't forget pics
- superstar
Re: hy~gain clr2
there’ll be pics, just gotta check all nuts n bolts are there
i’ll try and get it up within the next few days
Cb handle
Cb handle
- The Collector
Re: hy~gain clr2
It'll look awesome, although it's one big bugger. Diameter of the legs is about 15ft
Re: hy~gain clr2
If you don't report back within a few days with photos we'll just presume you've done a rod hull
