York 863 audio chip
NightProwler
Call Sign: 163TM186
Re: York 863 audio chip
Post by NightProwler »
Just switched it on and I have noticed something new, I am getting audio out of it as normal now but as you turn the volume up further the audio dies away :eh: I think this York is possessed as it was not doing this before. Still no out going audio either. Strange :think:
cb4ever104
Post by cb4ever104 »
NightProwler wrote: 24 Apr 2018, 21:23 Just had a quick look and C102 appears to be leaking, The others look ok. I'll replace them and report back. Thanks for your help :thumbup:
I'd be tempted to replace them all now anyway . Regardless .
Sammy
NightProwler
Call Sign: 163TM186
Aye that's what I will do. Still puzzled why the volume now vanishes when turned up :think:
Post by ch25 »
What is the voltage on output pin of audio IC?
NightProwler
Call Sign: 163TM186
About 0.4V
Post by ch25 »
Too low. Should be 1/2 power supply voltage.
Remove C102, 103, 104, 105 and measure again. If lower than 1/2 PS voltage, IC need to be replaced.
NightProwler
Call Sign: 163TM186
Well I replaced the caps and it's still the same so now it's time to change the audio chip.
NightProwler
Call Sign: 163TM186
Finally got around to replacing the audio chip but it's still the same :think:
Post by ch25 »
Check voltages according to that schematic: http://www.m0ysu.com/files/134AOXboardS ... -2017b.jpg
NightProwler
Call Sign: 163TM186
Just checked the voltages and each pin is showing about 0.1V some showing nothing at all.
Post by ch25 »
You measure it against chassis ground or PCB ground?
NightProwler
Call Sign: 163TM186
Chassis ground
Post by ch25 »
Wrong.
NightProwler
Call Sign: 163TM186
Right just tried PCB ground and im getting readings, Will check if they are correct :thumbup:
Buick Mackane
Post by Buick Mackane »
ch25 wrote: 11 May 2018, 23:14Wrong.
Do it again :D
