York 863 audio chip
- NightProwler
- Call Sign: 163TM186
Re: York 863 audio chip
Just switched it on and I have noticed something new, I am getting audio out of it as normal now but as you turn the volume up further the audio dies away I think this York is possessed as it was not doing this before. Still no out going audio either. Strange
- cb4ever104
I'd be tempted to replace them all now anyway . Regardless .NightProwler wrote: ↑24 Apr 2018, 21:23 Just had a quick look and C102 appears to be leaking, The others look ok. I'll replace them and report back. Thanks for your help
Sammy
- NightProwler
Aye that's what I will do. Still puzzled why the volume now vanishes when turned up
What is the voltage on output pin of audio IC?
- NightProwler
Too low. Should be 1/2 power supply voltage.
Remove C102, 103, 104, 105 and measure again. If lower than 1/2 PS voltage, IC need to be replaced.
- NightProwler
Well I replaced the caps and it's still the same so now it's time to change the audio chip.
- NightProwler
Finally got around to replacing the audio chip but it's still the same
Check voltages according to that schematic: http://www.m0ysu.com/files/134AOXboardS ... -2017b.jpg
- NightProwler
Just checked the voltages and each pin is showing about 0.1V some showing nothing at all.
You measure it against chassis ground or PCB ground?
- NightProwler
Wrong.
- NightProwler
Right just tried PCB ground and im getting readings, Will check if they are correct
- Buick Mackane
