Rm 203 set up
original45
Call Sign: 45
Rm 203 set up
Post by original45 » 08 May 2018, 18:42
I had bought this some time back now and will set it up soon .
My question is I can remember back in the 80 s I had a cte model and I'm sure if I remember correctly if you had linear set up to the radio and antenna you had to have a constant power to it to be able to use the cb radio whether or not the amp was switched to on .
Something about damaging internals in amp.
Is this the case with the 203 if it's all connected up and I use my radio does the 203 require it to have a 12v input supply live to it to use the radio with amp not running but still connected to radio antenna.
Call Sign: n0call
Re: Rm 203 set up
Post by ch25 » 08 May 2018, 19:12
You can have 203 inline without power connected to it.
original45
Call Sign: 45
Re: Rm 203 set up
Post by original45 » 09 May 2018, 13:52
Thank you Chris. Appreciated.
As much as I looked online I couldn't find the answer.
Cheers again
original45
Call Sign: 45
Re: Rm 203 set up
Cheers again
Re: Rm 203 set up
Post by The Collector » 09 May 2018, 17:27
From 1980's memory, if it's got a power on/off switch on it, you can usually use it connected whilst not powering it up. Those without a switch, usually have to be removed if wanting to use the radio "barefoot".
original45
Call Sign: 45
Re: Rm 203 set up
Post by original45 » 10 May 2018, 20:32
Thanks for that. I shall do my best to remember this for future need.
