Tango Mike Membership Requests (Old Thread)
- MrWeetabix
- Admin
- Call Sign: 26TM175
If you would like to join the Tango Mike DX group then please post in this thread with your choice of unit number. Basically you can have any number between 001-9999 providing it's not already been allocated in your country.
Membership is entirely free of charge to any registered user of Transmission1. QSL cards and a PO Box Service are also available
For detailed division numbers or if you are not sure what division you need to request please refer to the TM website to find your country at: http://www.tangomike.net/reference-pages/prefix-lists/
When requesting a membership we need to know the following information:
* Name (Just first name will do!)
* Location (eg. Scarborough, North Yorkshire)
* Desired unit number (Check availability via the links below)
England ( 26 Division) Callsign List - HERE
Rest-of-World availability Ireland, Northern Ireland, Scotland & Wales (29, 68, 108, 163) Callsign List - HERE
Rest Of World (Anything not covered above) Callsign List - HERE
Please don't post membership requests anywhere else on the forum other than in this thread. If they are posted elsewhere, they may not get noticed by the Tango Mike coordinator and could be removed.
Once you have joined please check out the official website of the group at:
- New User
Tango Mike Membership Requests 2018-2020
hi there,i'm already a member of tango mike and i'm askink if i can have the callsign 26tm1951 please .. i'm from Newcastle upon Tyne NE6
- New User
Re: Tango Mike Membership Requests 2018
hi there i would like to join the Tango Mike DX group please my name is David my location is Newcastle upon Tyne and please could i have the call sign 26-TM-1951 please
- MrWeetabix
- Admin
That's all done for toy David. You can use it immediately. Where abouts in Newcastle are you? Cheers
26-TM-1951 - David (mewtiny), Newcastle Upton Tyne
Hi TM,
I would like the call sign TM9484 if that is possible ?
Regards
Dj1
Regards
Dj1
- MrWeetabix
- Admin
As-per the first post on the thread, can I have your name and location too please Deejay? Ta
- New User
sorry for the late reply MrWeetabix,,I'm from Walker,,Pottery Bank to be preciseMrWeetabix wrote: ↑01 Apr 2018, 14:36 That's all done for toy David. You can use it immediately. Where abouts in Newcastle are you? Cheers
- MrWeetabix
- Admin
I'll have to have a listen out for you. I don;t get out that way fantastically, but I should just about scrape through
- Call Sign: M0VPL
Hi I would like to join the tango mike DX group please.
Name Matty location Bognor, and would like the call 26-TM-9000
thanks
thanks
C.B got me into radio. Ham radio followed later. I enjoy it all. pride and joy a FTdx9000D. FTdx3000D TS2000X 23cm
DR.E 400 DV 2m/70cm TR-751 2m wouxun KG-UV950P 4 mtrs FT-840 CB Superstar 360fm (got to be uniden)
- MrWeetabix
- Admin
Hi Matty, that has been issued for you and can be used straight away. Welcome to Tango Mike! :-)
- MrWeetabix
- Admin
- Call Sign: 26TM1009
Hi,
Could I please register as 26TM1009? My name is Tim and location is Oxfordshire.
Thanks in advance.
Thanks in advance.
Hi. Please could I have TM660?
Nick - Gloucestershire
- Call Sign: 26tm866
Hi i would like to join please
Eddie
Torbay devon
26 TM 866
If possible please
Eddie
Torbay devon
26 TM 866
If possible please
Hi guys requesting a tango mike call sign
Carl
Essex
Many thanks guys
Carl
Essex
Many thanks guys
