Help identifying these antennas
- NightProwler
- Call Sign: 163TM186
Can anyone please tell me what these antennas are?
First one is about 6 feet tall with no groundplanes.
Second one is about 21 foot tall and has 4 groundplanes.
Cheers all...
Cheers all...
- LeakyFeeder
Re: Help identifying these antennas
Top is an Alcom....i.think thats the spelling..bottom one is what believe to be an Electronica Special
- NightProwler
Thank you What band would the Alcom be used for as it's only about 6 foot high. I was thinking it's for 2M
- Call Sign: 26AT239
The first one is called a 'ringo'.
- LeakyFeeder
As i remember the Alcom they did a short CB version and a 19ft version. Old guy nr my parents had both n he put out a quite good signal on the shorter one...
That Electronica looks to be assembled wrong...
- NightProwler
Cheers guys. They came to me like this from a recent silent key. I dont have the grounplanes for the second one but I presume they should be about 9 feet long?
- superstar
Top one as said Alcom, the big one was the DPA11VR, the short one DPA 11UK, back in the day bloke next door had one on the stack, and bloke couple of doors away had one on the back of the house, ( the tall versions )
Topic here
viewtopic.php?t=12455
Topic here
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Cb handle
- NightProwler
Excellent, Thank you very much. Looking at it now it is 100% complete and in lovely condition. Ive never seen one before.
Cheers dudes
Cheers dudes
I thought the Electronica had a single turn large loop, that one looks like a later model from Tagra?
- prettypolly
- Call Sign: 26FB185
The bottom one is definitely Sirio tornado 27 ..some one has removed and uncoiled the coil ...
I have a 'ringo', have not tried it out yet.
- NightProwler
Ahhh give that man a cigar I can see now that the coil is in the wrong place. It was given to me like that. It's never been used but it's missing the groundplanes. I presume they would be 9 feet long?prettypolly wrote: ↑26 Mar 2018, 23:42 The bottom one is definitely Sirio tornado 27 ..some one has removed and uncoiled the coil ...
FWIW I just wanted to correct my post from last night, I was thinking about the Commtel AR5/8 from around 1983, this is one of the adverts for it on the back of Breaker on the Side magazine.
- NightProwler
Ahhh now in that picture it looks like the groundplanes have some sort of coil in the middle of them. I have 8 groundplanes here that came with it plus a load of other broken up antennas. Does anyone know if these are the correct ground planes? They are about 5 or 6 feet long.
Cheers dudes
Cheers dudes
- andrew013
- Call Sign: 26AT013
bottom one defo a tornado radilals should be approx 2000mm or 6ft 7 inch long
