Reducing power on ssb on superstar ss 9900
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 05 Mar 2018, 13:55
Hi all,can anyone tell me how to reduce the ssb output power on a ss9900 if I turn the dial fully down it's still doing over 50 watts.i want to turn it down to around 35 watts so it doesn't overdrive it all the time.
ROTEL240
Re: Reducing power on ssb on superstar ss 9900
Post by ROTEL240 » 05 Mar 2018, 14:47
Normally the pots are marked up i have backed off the echo delay and echo volume on my 9900 which are at the front of the board nr the channel knob so have a look inside for SSB PWR you will need a tiny cross head driver,i would also back the FM PWR right down as they are known for running very hot.Good luck..
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 05 Mar 2018, 16:34
Hi there,the FM was already turned down.it was just ssb I need to turn down a touch.thanks for the info.
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 05 Mar 2018, 20:47
Hi,all iv set up he ssb output to 40 watts high and its 5 watts on the he lowest. fm is set to 25 watts high and 1.5 lowest.thanks all.
ROTEL240
Post by ROTEL240 » 06 Mar 2018, 08:47
nice one were they labeled up,saves working the radio to hard and blowing the outputs.
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 06 Mar 2018, 10:58
Yes mate,it was easy to find,just near the ctss board.
ROTEL240
Post by ROTEL240 » 06 Mar 2018, 11:00
MrPaul009 wrote:
06 Mar 2018, 10:58
Thanks Paul :thumbup:
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 06 Mar 2018, 11:53
Hi,if anyone want to lower the power internally just watch the small vr screw.mine was very twitchy to setup.
