kl203p- new version ?
- Mudslinger
Re: kl203p- new version ?
I just run my fan from the power pack so that it is on all the time. It isn't any louder than the powerpack fan anyway. so it isn't an issue.
- gmham
- Call Sign: 108TM154
Ok perfect thanks yep as you say don't think it's much off an issue and have ordered a supposedly " silent fan " anyway ? Might use hexagonal pillars to mount the fan just above the heat sink , anyone else done this .. ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- prettypolly
- Call Sign: 26FB185
4 blobs of blutack works well
- gmham
yep I know !!! just fancy doing it a more permanent way.. !
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Mudslinger
I used a couple of cable ties around the fan and amp.
It has been ok for 4 years so must be quite permanent.
- gmham
Okay maybe permanent was the wrong word to use.. actually meant more professionally looking. !!
To be honest used the kl203 with the cable tie arrangement before and as you say does the job well. !!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Unit 148 Mobile
- Call Sign: G4ZOW
WA10,
I just read this thread through and you took the words out of my mouth re the 550 and I've never run one!
The 1407 datasheet says it all: https://www.mouser.com/ds/2/453/sd1407-13154.pdf so two do not equate to half a kilowatt or anywhere close, that is unless it's over-driven and you add all the harmonic content :-)
IMO the very best thing one can do with most all amplifiers and not just the RM's is to drive them with 50% of what the manufacturer states for drive.
You get better reliability, a cooler running amp and a cleaner signal through lower intermod distortion however you won't get the "Worked all Neighbors" award with a wide covering half the band.
RM would probably sell a lot fewer amplifiers if you adhered to the above.
Unit 148 Mobile
Unit 148 Mobile
- ROTEL240
works well for me also and stops any fan vibration on the linear..
- prettypolly
Or big rubber bands OK as well
148
Its more appealing to believe the amp makers impossible ratings when the truth sound much less impressive.
W8JI
- Mitch
- Call Sign: M1TCH
I've always believed that a linears power rating was the INPUT watts i.e. how much power it uses, so a 300W amp will take 21 amps or so at 13.8v. I wouldn't expect 300W out. Sounds more likely imho. The sales copywriters take the highest number for the ads, obviously, being sales people, they like the bigger numbers. I wouldn't expect any better than 40% efficiency either so it kinda fits for me.
The perfect face for radio.
- ghost123uk
- Call Sign: 26TM953
- andrew013
- Call Sign: 26AT013
me and a mate run rm kl 500`s when the need arises his does 250 mine does 380 , tested off the same battery , radio , swr , meter and dummy load and we tested his first input power was 15 w, it was his battery so i dont know how charged it was , but i do know from my fully charged battery that still bubbles straight off the charger i get 450 plus out of mine for how long i dont know and all i did to mine was upgrade the power cable and fuse holder , brigded the 3 internal fuse holders and put 2 thicker cables on the board somewhere
and its not worth the while sticking 10 into a 203 its alot happier running with an input from 6to 8 watts or less if you want it to run cool
- ghost123uk
