Are you going to replace the bulb with a blue LED thoughcb4ever104 wrote: ↑05 Feb 2018, 10:24You'll only get 3 rigs in there . You're going to need some more cabinets
What CB/11m Radio Stuff did you buy today? (2020)
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: What CB/11m Radio Stuff did you buy today? (2017)
- Crusader
Re: What CB/11m Radio Stuff did you buy today? (2018)
- superstar
Now there’s an idea:)MrWeetabix wrote: ↑05 Feb 2018, 13:52Are you going to replace the bulb with a blue LED thoughcb4ever104 wrote: ↑05 Feb 2018, 10:24You'll only get 3 rigs in there . You're going to need some more cabinets
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Cb handle
Spent a tenner on a mint 40ch mid-block FM handheld radio just for the telescopic aerial. Gonna resell it with a busted one fitted and a rubber duck stuck on instead.
- stanogs68
arthur daleyThe Collector wrote: ↑06 Feb 2018, 19:59 Spent a tenner on a mint 40ch mid-block FM handheld radio just for the telescopic aerial. Gonna resell it with a busted one fitted and a rubber duck stuck on instead.
love your familly
- MrWeetabix
- Admin
add the words 'Possibly a Jentec' to the description and you'll turn a profitThe Collector wrote: ↑06 Feb 2018, 19:59 Spent a tenner on a mint 40ch mid-block FM handheld radio just for the telescopic aerial. Gonna resell it with a busted one fitted and a rubber duck stuck on instead.
I wont be hiding the fact that the aerial's broken, unlike most sold on ebay. Third time lucky this one's all ok when it arrives and looking at the pic's it is The rubber duck will probably double the value of the handheld to some!stanogs68 wrote: ↑06 Feb 2018, 20:08arthur daleyThe Collector wrote: ↑06 Feb 2018, 19:59 Spent a tenner on a mint 40ch mid-block FM handheld radio just for the telescopic aerial. Gonna resell it with a busted one fitted and a rubber duck stuck on instead.
- superstar
An Elbex Veep, same as a president veep but badged “Elbex”
Cb handle
Cb handle
- superstar
Yeah I’d never heard of Elbex until I saw that, but there’s a few models out there
Cb handle
Cb handle
- 14CS06
- superstar
I’ll have a look over the weekend Claude, the volume and squelch need a squirt of switch cleaner so I’ll look then
Cb handle
Cb handle
- superstar
Just had a look Claude, yes it is
Cb handle
Cb handle
- Mudslinger
I fancied myself a cheap new and didn't fancy a CRT 1 or the clones so I went for one of these.
Seller accepted £41.50 all in.
https://www.ebay.co.uk/itm/CB-Radio-Mob ... 2749.l2649
- superstar
Don’t get too excited you lot, I have a cobra 21X on the way!
Cb handle
Cb handle
