HF VOLMET
HF VOLMET
i have just moved house and put a 60 ft long wire from house to bottom of garden....wire is going from east to west...just like it was before i moved....i did used to pick up ametures , and air band , volmets but canot hear anything ...i know there canot be mutch wrong because i can pick up the shortwave radio stations on am.....can someone tell me what volmets are easy to pick up so that i can test the radio on[ usb lsb ] please can you tell me what most shortwave listiners tune into.....
- Ur5by9
Re: HF VOLMET
Bit of activity on 40m amateur band tonight 7.130 sideband Moscow and Russia with some big signals
Re: HF VOLMET
Easiest one is RAF Volmet on 5450khz or Shannon Volmet 5505khz,although this one has been a bit sporadic lately.
- Andy
Re: HF VOLMET
Could be a new noise source nearby. I've just got a new one popped up that puts a picket-fence of spikes from about 250 KHz to 400 KHz. It only comes on at night but it's still a !£$%^&*£$! pain.
'SOMEONE GET ME A SAW!'
Andy.
Andy.
Re: HF VOLMET
this is a bl-.,,dy night mare picking up RAF Volmet on 5450khz but with a lot off interferance.....the only thing i can pick up to listen to with some good audio are the am frequencies. verry flustrating...
- Andy
Re: HF VOLMET
Make a loop aerial, Gerald. When I changed from wires to a Wellbrook loop, most of my noise problems vanished.
Andy.
Andy.
- Andy
Re: HF VOLMET
It's not critical, about 1m dia will do. A single turn with the ends connected to a simple PA1M-type amplifier and you are away. Mount it well away from the house and rotate it for minimum noise.
http://www.pa1m.nl/pa1m/simple-active-receive-loop/
Andy.
Andy.
Re: HF VOLMET
thanks for that Andy ...and the link. will have a go at making the loop .and let you know how it does.Andy wrote: ↑10 Feb 2018, 00:34It's not critical, about 1m dia will do. A single turn with the ends connected to a simple PA1M-type amplifier and you are away. Mount it well away from the house and rotate it for minimum noise.
- Call Sign: 2e1mha
Re: HF VOLMET
gerald123 wrote: ↑06 Feb 2018, 19:18 i have just moved house and put a 60 ft long wire from house to bottom of garden....wire is going from east to west...just like it was before i moved....i did used to pick up ametures , and air band , volmets but canot hear anything ...i know there canot be mutch wrong because i can pick up the shortwave radio stations on am.....can someone tell me what volmets are easy to pick up so that i can test the radio on[ usb lsb ] please can you tell me what most shortwave listiners tune into.....
[/quotE
I have most of the HF volmet freqencies programmed into my portable HF reciever. i can't tell you exact freqencies [bad memory to to age] but they're all online, google it. i can tell you Gander In Canada comes across very well here in the uk from like 12am till 6am. around 6.628usb. also around 4mhz. shanwick in ireland booms across around 5.4mhz most days. with a 60 foot wire you should do reasonable well assuming you "noise" floor is'nt to high.
- KURG3N
Re: HF VOLMET
Anyone know where to Find out whats the problem with RAF Volmet Military 1, been silent for last couple of days on both Frequencies..
- Call Sign: 26DG01
- thedeerhunter270
Re: HF VOLMET
I don't think the MOD run it though. I have a feeling its Babcock.
- Mikel
Re: HF VOLMET
Full scale here on 5450khz, but St. Eval is only about 100 miles away from my home QTH as the crow flies.
